Home » Modeling » ATL » The class 'VisitableCS' is not a valid classifier(OCL MDT error)
The class 'VisitableCS' is not a valid classifier [message #1000786] Tue, 15 January 2013 07:39 Go to next message
Fi Fi is currently offline Fi Fi
Hi all,
I try to use to atl query to generate a very simple text form a parsed OCL document
conforms to CompleteOCLCST metamodel proposed by OCL MDT community.
this is the query
query Variable =
	CompleteMetaModel!CompleteOCLDocumentCS.allInstances()->asSequence()->first()
		.generateText().writeTo('/Users/text.txt');
helper
context CompleteMetaModel!CompleteOCLDocumentCS
def : generateText() : String =
'aa';
An error is gnerated which is
Error loading platform:/resource/CompleteOCL/Test.xmi: The class 'VisitableCS' is not a valid classifier
Can you please help to identify the source of this error
Fy Za
[Updated on: Tue, 15 January 2013 07:49]
Report message to a moderator
Re: The class 'VisitableCS' is not a valid classifier [message #1000798 is a reply to message #1000786] Tue, 15 January 2013 07:51 Go to previous messageGo to next message
Did you call CompleteOCLStandaloneSetup.doSetup() ?
Ed Willink
On 15/01/2013 12:39, Fy Za wrote:
> Hi all,
> I try to use to atl query to generate a very simple text form a parser
> OCL document conforms to CompleteOCLCST metamodel proposed by OCL MDT
> community.
> this is the query
> query Variable =
> helper
> 'aa';
> Best regards,
> Fy Za
Re: The class 'VisitableCS' is not a valid classifier [message #1000800 is a reply to message #1000798] Tue, 15 January 2013 07:55 Go to previous messageGo to next message
I parse the OCL document using save as xmi
Best regards
Fy Za
[Updated on: Tue, 15 January 2013 07:55]
Re: The class 'VisitableCS' is not a valid classifier [message #1001752 is a reply to message #1000800] Thu, 17 January 2013 05:26 Go to previous messageGo to next message
I think that "save as xmi" produce the same output as using CompleteOCLStandaloneSetup.doSetup().
That is right?
Fy Za
Re: The class 'VisitableCS' is not a valid classifier [message #1001760 is a reply to message #1001752] Thu, 17 January 2013 05:29 Go to previous messageGo to next message
Well if you think that you might as well save time and just write
System.println("This program doesn't work") since that might produce the
same output too.
Why on earth would an initialization routine be the same as a resource save?
Ed Willink
On 17/01/2013 10:26, Fy Za wrote:
> That is right?
> Best regards,
> Fy Za
Re: The class 'VisitableCS' is not a valid classifier [message #1001769 is a reply to message #1001760] Thu, 17 January 2013 05:47 Go to previous messageGo to next message
I use the output of this parser
But the same error was generated
package Parser;
import java.io.IOException;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.ocl.examples.pivot.model.OCLstdlib;
import org.eclipse.ocl.examples.xtext.completeocl.CompleteOCLStandaloneSetup;
import org.eclipse.ocl.examples.xtext.oclinecore.OCLinEcoreStandaloneSetup;
public class Parser {
	public static void main(String[] args) throws IOException {
		CompleteOCLStandaloneSetup.doSetup();
		OCLinEcoreStandaloneSetup.doSetup();
		OCLstdlib.install();
		ResourceSet resourceSet = new ResourceSetImpl();
		Resource resource = resourceSet.createResource(URI.createURI(args[0]));
		resource.load(null);
		EcoreUtil.resolveAll(resource);
		Resource resourceAsXmi = resourceSet.createResource(URI.createURI(args[0]+".xmi"));
		resourceAsXmi.getContents().addAll(resource.getContents());
		resourceAsXmi.save(null);
Re: The class 'VisitableCS' is not a valid classifier [message #1003309 is a reply to message #1001769] Sun, 20 January 2013 18:34 Go to previous message
Hi Ed
I am really sorry if you do not like my answer because I confused between AST and CST.
in the parser, I use CompleteOCLStandaloneSetup.doSetup() but the error still persists.
Fy Za
Previous Topic:ATL write to file
Next Topic:How to delete a model element of rule ?
Current Time: Sun May 26 05:22:36 EDT 2013
Powered by FUDForum. Page generated in 0.01848 seconds
