Home » Eclipse Projects » Eclipse Platform » No more handles [gtk_init_check() failed]
No more handles [gtk_init_check() failed] [message #998978] Thu, 10 January 2013 23:32 Go to next message
Akshay Jadye is currently offline Akshay Jadye
We have created an eclipse application which is intended to run in the headless mode, , i.e. from the command-line without the usage of the Eclipse GUI. We are using Eclipse Indigo (3.7.2)
On Windows it is working fine, but on Linux, it fails with the following exception:
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.start() of bundle org.eclipse.ui.ide.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
... 48 more
Caused by: org.eclipse.swt.SWTError: No more handles [gtk_init_check() failed]
at org.eclipse.swt.SWT.error(SWT.java:4308)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:909)
at org.eclipse.swt.widgets.Display.create(Display.java:897)
at org.eclipse.swt.graphics.Device.<init>(Device.java:157)
at org.eclipse.swt.widgets.Display.<init>(Display.java:500)
at org.eclipse.swt.widgets.Display.<init>(Display.java:491)
at org.eclipse.swt.widgets.Display.getDefault(Display.java:1681)
at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.createProblemsViews(IDEWorkbenchPlugin.java:394)
at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.start(IDEWorkbenchPlugin.java:351)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 54 more
The same application when run on Eclipse Helios (3.6.2) works fine on both Windows and Linux.
Is there any work around or a way in which we can run the application in headless mode.
Re: No more handles [gtk_init_check() failed] [message #1000285 is a reply to message #998978] Mon, 14 January 2013 07:40 Go to previous messageGo to next message
Thorsten Meinl is currently offline Thorsten Meinl
Member
Have you tried setting java.awt.headless=true?
Am 11.01.2013 15:09, schrieb Akshay Jadye:
> exception:
> org.eclipse.ui.ide.
> at
> at
> at
> at
> at
> at
> at
> ... 48 more
> failed]
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 54 more
> headless mode.
Re: No more handles [gtk_init_check() failed] [message #1000645 is a reply to message #1000285] Tue, 15 January 2013 01:58 Go to previous message
yes, i have tried with java.awt.headless=true. But still the issue exists.
Previous Topic:Target Definition
Next Topic:Unable to run Eclipse Helios on windows 7 with jdk
Current Time: Thu May 23 16:22:33 EDT 2013
Powered by FUDForum. Page generated in 0.01587 seconds
