Home » Eclipse Projects » Eclipse 4 » Scrolling a JFace Viewer
Scrolling a JFace Viewer [message #1000362] Mon, 14 January 2013 10:46 Go to next message
Joel Becker is currently offline Joel Becker
When I add items to my ListViewer, I need to scroll it down such that the newest item is visible. The only possibility I could find was the ListViewer.scrollDown() method, which for testing I called with scrollDown(0, 100) whenever an item was added, but this did nothing, beside being more low-level than preferred. How can one scroll a ListViewer to the bottom?
Re: Scrolling a JFace Viewer [message #1000659 is a reply to message #1000362] Tue, 15 January 2013 02:38 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk Fauth
although you are a the wrong forum as you have a question related to JFace and not about Eclipse 4, the answer is quite easy. Try to use the reveal(Object) method on your viewer. It will ensure that the given element is visible, scrolling the viewer if necessary.
Greez,
Dirk
Re: Scrolling a JFace Viewer [message #1000954 is a reply to message #1000659] Tue, 15 January 2013 14:11 Go to previous message
reveal()! there it is!
Thanks, Dirk.
Previous Topic:Why will EModelService not find the part Toolbar?
Next Topic:A service to replace Platform.getAdapterManager() ?
Current Time: Mon May 20 04:52:42 EDT 2013
Powered by FUDForum. Page generated in 0.03896 seconds
