Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] texo template files in external plugin
icon1.gif  [Texo] texo template files in external plugin [message #1000263] Mon, 14 January 2013 06:52 Go to next message
Emanuele Gesuato is currently offline Emanuele Gesuato
Hi there,
first of all thanks for all the support you are putting in texo.
We have an our eclipse plugin where we are extending some of the (nice) features of texo providing a way to integrate our EMF-models with our custom annotations.
We are looking for integrate texo templates inside our plugin: so users will not have to worry about location of texo templates (for instance). But looking on texo source code it seems that is not possible to locate texo template in the plugin.
TexoResourceManager.getTemplateFolderPath returns template location but it is possible to overwrite this mechanism in order to look for template files inside our plugin ?
Re: [Texo] texo template files in external plugin [message #1000294 is a reply to message #1000263] Mon, 14 January 2013 08:00 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Emanuele,
Not directly possible now, but it for sure seems an interesting thing to support. How would a path/url to these template
look like?
And how do you generate code, you call the code generator yourselve from a plugin (so programmatically), or do you use
the standard Texo menus?
gr. Martin
On 01/14/2013 12:52 PM, Emanuele Gesuato wrote:
> Hi there,
> plugin.
> Thanks
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] texo template files in external plugin [message #1000304 is a reply to message #1000294] Mon, 14 January 2013 08:26 Go to previous messageGo to next message
Thanks for the quick response !
We would like to put templates files in a source folder of our plugin.
I think something like this:
this.getClass().getClassLoader().getResourceAsStream("com/myplugin/templates/mytemplate.xpt")
could do the job.
We are also calling code generation programmatically. But I think it could be great to support both: standard texo menu and "custom" call.
Thanks again,
Emanuele
Re: [Texo] texo template files in external plugin [message #1000322 is a reply to message #1000304] Mon, 14 January 2013 09:24 Go to previous messageGo to next message
Hi Emanuele,
Can you enter a bugzilla for this? I am not sure if it has the highest priority. If you contribute some code that would
help ofcourse :-).
If you generate code programmatically then you can tell Texo to use your specific TexoResourceManager. The
TexoResourceManager is a TexoComponent and can be replaced by your own implementation:
http://wiki.eclipse.org/Texo/Components
In the artifactgenerator it can be set explicitly also.
This would be a solution for you?
gr. Martin
> could do the job.
> and "custom" call.
> Thanks again,
> Emanuele
The Netherlands
Re: [Texo] texo template files in external plugin [message #1000812 is a reply to message #1000322] Tue, 15 January 2013 08:13 Go to previous message
Hi Martin,
We are using a custom implementation of TexoResourceManager and it is working like a charm ! It is a perfect solution, thanks.
Emanuele
Previous Topic:texo webservice support for nested packages
Next Topic:How to change the default fill color of EClasses in the Ecore Tools Diagram Editor?
Current Time: Sun May 19 23:22:00 EDT 2013
Powered by FUDForum. Page generated in 0.01995 seconds
