Home » Modeling » EMF » Loading Resource from EMF generated Plugin
Loading Resource from EMF generated Plugin [message #1000212] Mon, 14 January 2013 04:18 Go to next message
Florian Wartenberg is currently offline Florian Wartenberg
I have created an Ecore file then a genmodel from this file and used the option "generate all" afterwards I exported the plugins via the export wizard and put them into the dropins folder. Now I can use my plugin without any problem excpet when trying to load the ecore file as a resource into another ecore file.
1. Create a new Java project
2. Create a new Ecore model
3. Load Resource
4. Browse registered Packages
5. Select the relevant plugin
Then I get the following error:
Problems encountered in file "platform:/plugin/<pluginname>/model/<ecoremodel>.ecore
     Resource '/<pluginname>/META-INF/MANIFEST.MF/model/<ecoremodel>.ecore' does not exist
But stranegly when I run the generated Project as an Ecplise Application I can load the resource without any problems.
I would very much to resolve this problem hence I need to load my model as a resoure in several other ecore models.
F. Wartenberg
Re: Loading Resource from EMF generated Plugin [message #1000220 is a reply to message #1000212] Mon, 14 January 2013 04:50 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Florian,
Which version of EMF are you trying this with?
> 3. Load Resource
> 4. Browse registered Packages 5. Select the relevant plugin
> Resource
> exist
> Regards
> F. Wartenberg
Re: Loading Resource from EMF generated Plugin [message #1000224 is a reply to message #1000220] Mon, 14 January 2013 05:02 Go to previous messageGo to next message
I am running the latest Juno release with modeling components and I am using the
Eclipse Modeling Framework Core Runtime
Version: 2.9.0.v20121213-0932
Build id: S201212130932
Re: Loading Resource from EMF generated Plugin [message #1000229 is a reply to message #1000212] Mon, 14 January 2013 05:11 Go to previous messageGo to next message
The 'dropins' folder was deprecated long ago since it conflicts with
P2's ability to ensure installation integrity.
Last time I tried to use it, it didn't do anything useful for me.
Ed Willink
Re: Loading Resource from EMF generated Plugin [message #1000231 is a reply to message #1000224] Mon, 14 January 2013 05:16 Go to previous messageGo to next message
Florian,
I think I fixed that with this commit:
http://git.eclipse.org/c/emf/org.eclipse.emf.git/commit/?id=9332ec8af8dafbc9698c4dee540552e785459d2f
So if you could try a recent (nightly) build, it probably works properly.
> using the Eclipse Modeling Framework Core Runtime
Re: Loading Resource from EMF generated Plugin [message #1000232 is a reply to message #1000229] Mon, 14 January 2013 05:19 Go to previous messageGo to next message
Ed Willink wrote on Mon, 14 January 2013 05:11
Ed Willink
Ok this is what I thought too so I created a feature project and a update site project and created an archive then I installed the plugin. Everything worked fine except for this issue wich still was not resolved.
regards
Florian
[Updated on: Mon, 14 January 2013 05:22]
Report message to a moderator
Re: Loading Resource from EMF generated Plugin [message #1000238 is a reply to message #1000231] Mon, 14 January 2013 05:31 Go to previous messageGo to next message
Florian,
How do I install this nightly build?
regards
Florian
Re: Loading Resource from EMF generated Plugin [message #1000245 is a reply to message #1000238] Mon, 14 January 2013 05:42 Go to previous messageGo to next message
http://download.eclipse.org/modeling/emf/emf/updates/nightly
On 14/01/2013 11:31 AM, Florian Wartenberg wrote:
> Quote:
>> Florian,
>> properly.
>> am > using the Eclipse Modeling Framework Core Runtime
> regards
> Florian
Re: Loading Resource from EMF generated Plugin [message #1000281 is a reply to message #1000245] Mon, 14 January 2013 07:37 Go to previous message
I installed the Nighly Build and you were right now it works properly in every way I expect it to be thanks as always!
regards
Florian
Previous Topic:[CDO] multiple merge between branches
Next Topic:[CDO] Query & Lucene
Current Time: Tue May 21 20:09:17 EDT 2013
Powered by FUDForum. Page generated in 0.02692 seconds
