  Ve disappeared after upgrade
By: Eclipse User on Thu, 01 February 2007
0 1105 Thu, 01 February 2007 12:27
  UnUnderstanding of a problem in a visual class
0 1360 Thu, 01 February 2007 11:14
  Changing of cards by clicking on buttons
0 1036 Thu, 01 February 2007 07:14
0 1775 Thu, 01 February 2007 07:14
0 1117 Thu, 01 February 2007 07:12
0 1806 Thu, 01 February 2007 07:12
0 1050 Thu, 01 February 2007 07:07
0 1937 Thu, 01 February 2007 07:07
  VE 1.2.3_jem - What changes
By: Francesc Rosés on Wed, 31 January 2007
4 1607 Thu, 01 February 2007 06:12
By: Francesc Rosés
  Java 6 and Matisse
By: Eclipse User on Wed, 31 January 2007
2 2186 Wed, 31 January 2007 15:48
By: Francesc Rosés
0 1168 Wed, 31 January 2007 15:37
By: Francesc Rosés
  Java 6 and Matisse
0 1056 Wed, 31 January 2007 00:01
  Using the Visual Editor
By: Eclipse User on Tue, 30 January 2007
0 1038 Tue, 30 January 2007 17:48
0 1751 Tue, 30 January 2007 17:48
  Setting Cardlay out for multiple components in a container
By: Eclipse User on Sat, 27 January 2007
2 1186 Mon, 29 January 2007 15:09
  Restoring the visual setting at the time of restart
2 1522 Mon, 29 January 2007 15:06
0 1231 Sat, 27 January 2007 11:54
0 1693 Sat, 27 January 2007 11:48
  Removing/Hiding Java Source Code Window in Visual Editor
By: Gaurav Mehta on Tue, 23 January 2007
0 1627 Tue, 23 January 2007 08:35
By: Gaurav Mehta
By: Saurabh on Tue, 23 January 2007
0 1555 Tue, 23 January 2007 08:32
By: Saurabh
By: Eclipse User on Tue, 23 January 2007
0 2921 Tue, 23 January 2007 08:32
0 1570 Tue, 23 January 2007 08:25
By: Saurabh
0 2207 Tue, 23 January 2007 08:25
  Where does VE generate eCore before it transfoms it Java
0 1646 Tue, 23 January 2007 05:03
By: Gaurav Mehta
0 2159 Tue, 23 January 2007 05:03
By: Gaurav Mehta
  How to use shared images in VE
By: Tami Takamiya on Mon, 22 January 2007
0 1683 Mon, 22 January 2007 21:18
By: Tami Takamiya
0 2412 Mon, 22 January 2007 21:18
By: Tami Takamiya
  VE Won't Start Without Error
By: Eclipse User on Sun, 21 January 2007
0 1656 Sun, 21 January 2007 04:31
0 2501 Sun, 21 January 2007 04:31
  Extending and adding a SWT Button as a new control in Visual Editor
By: Eclipse User on Fri, 19 January 2007
4 3187 Sat, 20 January 2007 17:33
By: Eric Clayberg
  Extending Visual Editor to generate XML instead of Java code
By: Sunil on Fri, 19 January 2007
0 1722 Fri, 19 January 2007 23:32
By: Sunil
By: Sunil Ramaiah on Fri, 19 January 2007
0 1791 Fri, 19 January 2007 01:40
By: Sunil Ramaiah
  SWT problem: unable to change size when gridlayout is used
By: Eclipse User on Thu, 18 January 2007
8 2495 Fri, 19 January 2007 01:11
0 1766 Thu, 18 January 2007 01:06
  How to test a BeanInfo
By: Daniel Rohe on Sun, 14 January 2007
6 3757 Thu, 18 January 2007 00:20
By: Daniel Rohe
  Where are VE's code generation templates???
By: Eclipse User on Tue, 16 January 2007
0 1494 Tue, 16 January 2007 18:37
0 2383 Tue, 16 January 2007 18:37
  VE SWT help extending jface components?
By: Bud Curtis on Mon, 15 January 2007
0 1628 Mon, 15 January 2007 23:18
By: Bud Curtis
By: Eclipse User on Mon, 15 January 2007
0 2758 Mon, 15 January 2007 23:18
0 1734 Sun, 14 January 2007 16:22
By: Daniel Rohe
  creating tab using button but get error NullPointerException and visual editor can't works correctly
By: Nick on Sun, 14 January 2007
0 1699 Sun, 14 January 2007 07:19
By: Nick
By: Eclipse User on Sun, 14 January 2007
0 2550 Sun, 14 January 2007 07:19
  Extending VE Code generation to generate XML
By: Sunil on Fri, 12 January 2007
0 1715 Fri, 12 January 2007 22:42
By: Sunil
By: Eclipse User on Fri, 12 January 2007
0 2217 Fri, 12 January 2007 22:42
  Extending VE
By: Sunil Ramaiah on Fri, 12 January 2007
0 1668 Fri, 12 January 2007 22:29
By: Sunil Ramaiah
  Extending VE
0 2220 Fri, 12 January 2007 22:29
  How to add a CheckboxGroup in VE???
0 1694 Fri, 12 January 2007 20:44
0 2681 Fri, 12 January 2007 20:44
  Extending VE Palette: EMF problem
0 1894 Fri, 12 January 2007 15:24
  Call a view perspective from a java class
0 1562 Fri, 12 January 2007 08:02
0 2324 Fri, 12 January 2007 08:02
  Help,how to solve this java.lang.NullPointerException
By: Nick on Fri, 12 January 2007
0 1670 Fri, 12 January 2007 05:41
By: Nick
  VE and Macos-X
By: Eclipse User on Wed, 10 January 2007
8 2870 Wed, 10 January 2007 15:59
  VE and Macos-X
By: Thomas on Wed, 10 January 2007
0 1743 Wed, 10 January 2007 08:36
By: Thomas
  Deleting contents from VE Palette
By: MKTX on Mon, 08 January 2007
2 1238 Mon, 08 January 2007 14:54
  Using VE in J2ME environment
By: Anandatirtha on Mon, 08 January 2007
0 1684 Mon, 08 January 2007 09:54
By: Anandatirtha
0 3407 Mon, 08 January 2007 09:54
By: Anandatirtha
0 1733 Mon, 08 January 2007 05:43
By: MKTX
  VE support for C++ ???
By: Eclipse User on Fri, 05 January 2007
2 1196 Fri, 05 January 2007 23:37
0 1733 Fri, 05 January 2007 19:34
  Extending the VE palete
By: Eclipse User on Tue, 02 January 2007
10 1937 Thu, 04 January 2007 14:39
  developing a plugin
By: Eclipse User on Tue, 26 December 2006
2 1884 Wed, 03 January 2007 00:14
  Add component more than once
By: Eclipse User on Thu, 21 December 2006
2 1464 Wed, 03 January 2007 00:13
  Where is the SWT Components?
By: Eclipse User on Wed, 20 December 2006
2 1248 Wed, 03 January 2007 00:11
0 1613 Tue, 02 January 2007 06:51
  IndexedPropertyDescriptor
2 1387 Fri, 29 December 2006 00:02
By: Jeff Myers
  How do I change the templates for code generated by VE?
By: Eclipse User on Wed, 27 December 2006
0 1626 Wed, 27 December 2006 21:56
0 2223 Wed, 27 December 2006 21:56
  NullPointerException when showing JPanel
By: Andreas Eberlle on Tue, 21 November 2006
4 2748 Wed, 27 December 2006 09:33
By: Ross__
  Some custom JavaBeans do not show up in VE (i know why but don't know how to fix :)
By: Ross__ on Wed, 27 December 2006
0 1587 Wed, 27 December 2006 09:26
By: Ross__
0 2306 Wed, 27 December 2006 09:26
By: Ross__
  VE in debug mode extrem slowly
0 1478 Wed, 27 December 2006 00:55
0 2187 Wed, 27 December 2006 00:55
  developing a plugin
0 1566 Tue, 26 December 2006 13:09
By: Marc on Thu, 21 December 2006
0 1814 Thu, 21 December 2006 23:22
By: Marc
  VE 1.3
By: Eclipse User on Fri, 15 December 2006
10 2623 Wed, 20 December 2006 16:29
  Using VE as an event-driven form designer
By: Steve Clark on Wed, 20 December 2006
2 1402 Wed, 20 December 2006 14:33
By: Konstantin Scheglov
0 1604 Wed, 20 December 2006 11:22
0 1481 Wed, 20 December 2006 09:06
By: Steve Clark
  Restore property value in Property View
0 1473 Wed, 20 December 2006 09:02
0 2053 Wed, 20 December 2006 09:02
0 1443 Wed, 20 December 2006 03:14
  radio buttons
By: Eclipse User on Mon, 18 December 2006
0 1346 Mon, 18 December 2006 13:48
  radio buttons
0 2245 Mon, 18 December 2006 13:48
  how to load my Customized Constructor
By: Eclipse User on Wed, 13 December 2006
2 1321 Mon, 18 December 2006 04:15
  VE 1.3
0 1531 Fri, 15 December 2006 21:58
  how to prevent the generation of default constructor
0 1512 Fri, 15 December 2006 11:18
0 2295 Fri, 15 December 2006 11:18
  VE customize layout problem
By: Defert Philippe on Thu, 14 December 2006
4 4331 Fri, 15 December 2006 10:46
By: Defert Philippe
  SWT as Library: how to configure source position?
By: Diego Guidi on Thu, 14 December 2006
4 1616 Fri, 15 December 2006 07:01
By: Diego Guidi
  Problems to set JME specific classpath while creating LCDUI like GUI editor with VE
By: Arto Laurila on Thu, 14 December 2006
0 1634 Thu, 14 December 2006 13:40
By: Arto Laurila
By: Eclipse User on Thu, 14 December 2006
0 2429 Thu, 14 December 2006 13:40
0 1554 Thu, 14 December 2006 10:02
By: Diego Guidi
0 1827 Thu, 14 December 2006 09:49
By: Defert Philippe
By: sanny on Wed, 13 December 2006
0 1385 Wed, 13 December 2006 05:23
By: sanny
  installation problem
By: Eclipse User on Sun, 10 December 2006
2 1497 Mon, 11 December 2006 16:18
  Two files the same - 1 UI painter works the other doesn't
By: Eclipse User on Sat, 09 December 2006
4 2963 Sun, 10 December 2006 21:47
0 1488 Sun, 10 December 2006 12:29
0 2163 Sat, 09 December 2006 14:07
  how to insert menu into my rcp?
0 1503 Sat, 09 December 2006 07:42
0 2271 Sat, 09 December 2006 07:42
0 1410 Sat, 09 December 2006 07:40
0 2018 Sat, 09 December 2006 07:40
  Problem in Setup Visual Java Editor: Initializing model
By: Eclipse User on Wed, 06 December 2006
0 1489 Wed, 06 December 2006 00:47
0 2144 Wed, 06 December 2006 00:47
  SWT Application with several shells
By: Eclipse User on Tue, 05 December 2006
4 1542 Tue, 05 December 2006 14:52
  Matisse for SWT!
By: Ivan Mising name on Sun, 10 September 2006
20 5812 Tue, 05 December 2006 08:43
0 1420 Tue, 05 December 2006 01:23
  Another case of VE not showing up after installation
By: Eclipse User on Fri, 01 December 2006
22 3696 Mon, 04 December 2006 22:52
  Changing default access
By: Eclipse User on Sat, 02 December 2006
2 1158 Mon, 04 December 2006 14:50
0 1359 Sat, 02 December 2006 15:37
By: exquisitus on Fri, 01 December 2006
0 1341 Fri, 01 December 2006 15:48
By: exquisitus
  Linking JMenuItem and JButton in toolbar
By: Steven Buroff on Wed, 29 November 2006
0 1418 Wed, 29 November 2006 17:15
By: Steven Buroff
0 2417 Wed, 29 November 2006 17:15
By: Steven Buroff
  VE problem
By: Eclipse User on Mon, 27 November 2006
14 2238 Wed, 29 November 2006 14:56
  java.lang.NullPointerException in VE
By: Eclipse User on Wed, 12 July 2006
26 7118 Tue, 28 November 2006 15:14
  How to create widgets in VE with respect to eSWT
By: sanny on Tue, 28 November 2006
0 1561 Tue, 28 November 2006 11:12
By: sanny
By: Eclipse User on Tue, 28 November 2006
0 1994 Tue, 28 November 2006 11:12
4 1503 Tue, 28 November 2006 09:34
  test - please ignore!
0 1563 Mon, 27 November 2006 20:41
0 2320 Mon, 27 November 2006 20:41
  VE problem
0 1538 Mon, 27 November 2006 20:28
  Automatically generated UI code
By: Eclipse User on Thu, 23 November 2006
4 1345 Mon, 27 November 2006 16:14
  VE brings up Print dialog
By: Eclipse User on Mon, 20 November 2006
4 1571 Mon, 27 November 2006 16:08
By: sanny on Mon, 27 November 2006
0 1433 Mon, 27 November 2006 12:24
By: sanny
  XML code generation
4 1379 Sun, 26 November 2006 23:26
  Eclipse and QT ??
4 1989 Fri, 24 November 2006 07:07
  no jface (for me)
By: Eclipse User on Tue, 21 November 2006
2 1197 Thu, 23 November 2006 21:26
  Eclipse and QT ??
0 1086 Thu, 23 November 2006 21:08
  XML code generation
0 1134 Thu, 23 November 2006 19:41
By: Alex Blewitt on Thu, 23 November 2006
0 1212 Thu, 23 November 2006 17:12
By: Alex Blewitt
0 1112 Tue, 21 November 2006 18:43
By: Andreas Eberlle
  no jface (for me)
By: Mauro Condarelli on Tue, 21 November 2006
0 1116 Tue, 21 November 2006 08:23
0 1027 Mon, 20 November 2006 18:27
  Extend VE to accommodate any two widgets with code generation. With respect
By: sanny on Mon, 20 November 2006
0 1130 Mon, 20 November 2006 09:40
By: sanny
0 1717 Mon, 20 November 2006 09:40
  No SWT items in VE
By: Eclipse User on Tue, 14 November 2006
8 1568 Fri, 17 November 2006 03:11
  Renamed vars and VE no longer "sees" them
By: Mike Higginbotham on Wed, 15 November 2006
0 1277 Wed, 15 November 2006 22:10
By: Eclipse User on Wed, 15 November 2006
0 1617 Wed, 15 November 2006 22:10
  eclipse 3.2.1 and VE-runtime-1.2.2_jem.zip
2 7640 Tue, 14 November 2006 18:48
0 2440 Tue, 14 November 2006 17:13
  [FAQ] OS X Compatability
0 1007 Tue, 14 November 2006 10:30
0 1679 Tue, 14 November 2006 10:30
  Cannot Install VE
By: Eclipse User on Mon, 13 November 2006
4 1341 Tue, 14 November 2006 05:29
  No SWT items in VE
By: Evgeny on Tue, 14 November 2006
0 1071 Tue, 14 November 2006 00:32
By: Evgeny
  Cannot Install VE
By: JC on Mon, 13 November 2006
0 1040 Mon, 13 November 2006 06:30
By: JC
  Linking classes across projects
By: Eclipse User on Thu, 09 November 2006
10 1783 Sat, 11 November 2006 03:43
  getter and setter methods are private?
By: Eclipse User on Wed, 08 November 2006
4 2245 Thu, 09 November 2006 08:35
By: Mark Johnson on Thu, 09 November 2006
0 951 Thu, 09 November 2006 03:16
By: Mark Johnson
  Tab Folder Drops Tabs
By: Joseph Skora on Fri, 03 November 2006
16 2663 Wed, 08 November 2006 19:27
By: Joseph Skora
  How to add component from program to model?
By: Eclipse User on Tue, 07 November 2006
6 1581 Wed, 08 November 2006 17:39
By: Martin Fernau on Wed, 08 November 2006
0 1021 Wed, 08 November 2006 11:12
By: Martin Fernau
0 972 Tue, 07 November 2006 13:41
0 1123 Fri, 03 November 2006 23:15
By: Joseph Skora
  Regarding layout manager
By: Varun Balakrishnan on Fri, 03 November 2006
0 1149 Fri, 03 November 2006 06:22
0 1712 Fri, 03 November 2006 06:22
  VE Path Must Include... Error
By: Joseph Skora on Wed, 01 November 2006
6 2986 Fri, 03 November 2006 03:18
By: Joseph Skora
0 1144 Wed, 01 November 2006 18:52
By: Joseph Skora
  VE displays JTabbedPane incorrectly
By: Greg Renegar on Mon, 30 October 2006
4 2042 Wed, 01 November 2006 16:31
By: Greg Renegar
  Broken link in downloads page
By: Francesc Rosés on Sun, 29 October 2006
4 1858 Tue, 31 October 2006 23:50
By: Francesc Rosés
  CanŽt add objects to CBanner
By: Eclipse User on Mon, 23 October 2006
2 1062 Tue, 31 October 2006 15:46
  remote/debug/vmtraceout
By: Tami Takamiya on Mon, 23 October 2006
2 1286 Tue, 31 October 2006 15:40
  How to get EditDomain
By: Eclipse User on Mon, 30 October 2006
2 1307 Tue, 31 October 2006 15:33
0 1004 Mon, 30 October 2006 22:09
By: Greg Renegar
0 1093 Mon, 30 October 2006 12:44
0 1046 Sun, 29 October 2006 07:00
By: Francesc Rosés
  Parsing problems on Eclipse 3.2
By: Eclipse User on Fri, 06 October 2006
6 2718 Fri, 27 October 2006 10:25
By: Risto Luukkanen
  Cannot view subclassed form
By: Eclipse User on Tue, 24 October 2006
4 1592 Thu, 26 October 2006 20:13
By: Eric Clayberg
  UI Windows do not show up anymore...
By: Eclipse User on Sat, 21 October 2006
10 2678 Thu, 26 October 2006 12:31
0 978 Tue, 24 October 2006 05:18
  CDT & VE
By: M. Bashir Al-Noimi on Mon, 23 October 2006
4 1374 Mon, 23 October 2006 23:54
  CDT & VE
0 1062 Mon, 23 October 2006 22:09
0 936 Mon, 23 October 2006 16:52
0 1160 Mon, 23 October 2006 16:48
By: Tami Takamiya
By: Harel Ben Attia on Sat, 21 October 2006
0 1122 Sat, 21 October 2006 23:42
By: Harel Ben Attia
  Installation Problem
0 1043 Sat, 21 October 2006 17:56
0 1644 Sat, 21 October 2006 17:56
  ToolItem issue (for SWT)
By: M. Bashir Al-Noimi on Thu, 19 October 2006
2 1388 Thu, 19 October 2006 14:07
  AST Utility?
By: hanys on Thu, 19 October 2006
0 1089 Thu, 19 October 2006 13:32
By: hanys
  AST Utility?
0 1610 Thu, 19 October 2006 13:32
By: hanys
0 1183 Thu, 19 October 2006 00:23
  VE and JEM update manager
By: Eclipse User on Wed, 11 October 2006
2 1360 Wed, 18 October 2006 16:07
  Installed VE doesn't do SWT/JFace
By: Martin Thompson on Fri, 06 October 2006
8 3128 Wed, 18 October 2006 16:06
  Preventing the generation of default constructor
By: Eclipse User on Thu, 05 October 2006
10 1991 Wed, 18 October 2006 16:04
  Remove allocation code if cancel
By: hung on Tue, 11 July 2006
6 1865 Wed, 18 October 2006 15:59
  code generation/reverse engineering principle
By: hanys on Wed, 18 October 2006
0 1185 Wed, 18 October 2006 14:19
By: hanys
0 1826 Wed, 18 October 2006 14:19
By: hanys
  Invoke command programatically
By: hung on Tue, 17 October 2006
0 1123 Tue, 17 October 2006 17:19
By: hung
0 1670 Tue, 17 October 2006 17:19
By: hung
  What is going to VE team anyway ?
By: Ivan Mising name on Tue, 17 October 2006
0 1031 Tue, 17 October 2006 13:02
0 1841 Tue, 17 October 2006 13:02
  Component visualization in VE
By: Peter on Mon, 16 October 2006
0 1018 Mon, 16 October 2006 12:25
By: Peter
By: Eclipse User on Mon, 16 October 2006
0 1608 Mon, 16 October 2006 12:25
  VE and Java Web Start (or: does JARing VE work?)
2 1230 Mon, 16 October 2006 10:36
By: Mario Ortegón
0 1311 Wed, 11 October 2006 17:51
0 1081 Wed, 11 October 2006 15:44
  ClassCastException while adding a customwidget to another customwidget
By: Varun Balakrishnan on Wed, 11 October 2006
0 926 Wed, 11 October 2006 10:14
0 2128 Wed, 11 October 2006 10:14
  Distributing VE-developed standalone SWT application
By: Eclipse User on Mon, 09 October 2006
2 1843 Mon, 09 October 2006 13:46
  Regarding layout of customwidget
By: Varun Balakrishnan on Mon, 09 October 2006
2 1158 Mon, 09 October 2006 11:44
Current Time: Mon May 21 01:26:11 GMT 2018
Powered by FUDForum. Page generated in 0.02235 seconds
