Eclipse Community Forumsobtain webtools sourcecode - HOW ? cvs does not work ?
https://www.eclipse.org/forums/index.php/mv/msg/71411/223169/#msg_223169
Originally posted by: aaa.aa.aaa
I want to download webtools sourcecode
I have not found the package with source of builds in downlod section
(eclipse.otg) :-(
I have found only one way - CVS as in document http://wiki.eclipse.org/index.php/CVS_Howto
unfortunately :-( get:
c:\cvs>cvs -d :pserver:anonymous@dev.eclipse.org:80/cvsroot/eclipse login
Logging in to :pserver:anonymous@dev.eclipse.org:80/cvsroot/eclipse
CVS password:
cvs [login aborted]: unrecognized auth response from dev.eclipse.org:
HTTP/1.1 400 Bad Request ( The data is invalid. )
I need this sources, is there any way to get them ?
best regards
kris]]>2008-10-28T08:50:42-00:00Re: obtain webtools sourcecode - HOW ? cvs does not work ?
https://www.eclipse.org/forums/index.php/mv/msg/71411/223185/#msg_223185
Originally posted by: dcarver.starstandard.org
You can also get the source by installing the SDK version of the tools.
The source is included there.
Also the webtools source repository is in /cvsroot/webtools
And try using the standard port for cvs which is 2401 not port 80.
Dave
> (eclipse.otg) :-(
> CVS password:
> best regards
> kris
>]]>2008-10-28T12:38:37-00:00Re: obtain webtools sourcecode - HOW ? cvs does not work ?
https://www.eclipse.org/forums/index.php/mv/msg/71411/223193/#msg_223193
Thank you! Exactly what I was looking for
I get Connection refused, however this may be caused by LAN.
According to http://wiki.eclipse.org/index.php/CVS_Howto
This should work on port 80 anyway. If you know where to raport this
let me know...
best regards
kris]]>2008-10-28T12:51:48-00:00Re: obtain webtools sourcecode - HOW ? cvs does not work ?
https://www.eclipse.org/forums/index.php/mv/msg/71411/223201/#msg_223201
> (eclipse.otg) :-(
> CVS password:
> best regards
> kris
If it helps, according to the document, proxy.eclipse.org is on port 80,
not dev.eclipse.org. I believe you would leave the port off for
dev.eclipse.org and include port 80 if you are using proxy.eclipse.org.
