Eclipse Community ForumsService Endpoint disappears when starting new service
https://www.eclipse.org/forums/index.php/mv/msg/68893/215960/#msg_215960
Originally posted by: vsimons.web.de
my Configuration is:
Eclipse 3.3.2 (support for J2EE) with JBOSS 4.2.2.
If I create a top-down webservice with the Webservice-Wizard and start the
new developed service, a new service endpoint and WSDL can be accessed on http://localhost/Project_Name/services/...
If I then create a second service I can deploy it to the current running
server instance without errors (Server icon says synchronized and
Running). When I try to start the second service (within the wizard) the
service endpoint of the first service disappears but the first service
stays deployed. But my Proxyclient says that it can't invoke the first
service because no service endpoint is there.
On the other hand the second service is now running and has a working
service-endpoint.
If I try to start the first service again the same happens -> 2nd service
stays deployed but service endpoint from first service disappears.
Why is this happening and how can I start the first service manually
again? (jmx-console?)
I am searching now for many days for a possible reason without any success.
I am thankful for every possible explanation or solution
