Eclipse Community ForumsProblems with WTP Tutorial - Creating Bottom Up Web Service
https://www.eclipse.org/forums/index.php/mv/msg/68150/213823/#msg_213823
I followed exactly the instructions of the tutorial "Creating Bottom Up
Web Service via Apache Axis2". Everything worked fine until I tried to
deploy the web service to Tomcat. The error on the tomcat console says:
java.lang.NoClassDefFoundError: javax/xml/stream/XMLStreamException
at
org.apache.axis2.transport.http.AxisServlet.initConfigContex t(AxisServlet.java:511)
at org.apache.axis2.transport.http.AxisServlet.init(AxisServlet .java:431)
at
org.apache.axis2.transport.http.AxisAdminServlet.init(AxisAd minServlet.java:55)
at
org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:1161)
at org.apache.catalina.core.StandardWrapper.load(StandardWrappe r.java:981)
at
org.apache.catalina.core.StandardContext.loadOnStartup(Stand ardContext.java:4045)
at
org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4351)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1045)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:719)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:566 )
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 3)
Also in Eclipse the import of javax.xml.stream.XMLOutputFactory and
javax.xml.stream.XMLStreamException in HappyAxis.jsp can't be resolved.
I'm working with Eclipse 3.3.2, the latest WTP, Tomcat 6.0.14 and Axis2
1.4. Can anyone help me?
Bye - Reinhold.]]>Reinhold Bentele2008-05-14T13:43:33-00:00Re: Problems with WTP Tutorial - Creating Bottom Up Web Service
https://www.eclipse.org/forums/index.php/mv/msg/68150/213840/#msg_213840
of the Axis2 runtime specified in your Axis2 Preferences and it should
have been copied to the WEB-INF/lib of your project when it was created
in the tutorial.
Larry
Reinhold Bentele wrote:
> Hi all,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Bye - Reinhold.]]>Larry Isaacs2008-05-14T14:39:17-00:00Re: Problems with WTP Tutorial - Creating Bottom Up Web Service
https://www.eclipse.org/forums/index.php/mv/msg/68150/214740/#msg_214740
Originally posted by: rdargent.gmail.com
Hi Reinhold,
Have you solved your problem?
I am facing the same problem and I am still looking for a solution.]]>2008-06-02T18:34:53-00:00Re: Problems with WTP Tutorial - Creating Bottom Up Web Service
https://www.eclipse.org/forums/index.php/mv/msg/68150/218164/#msg_218164
Originally posted by: carla.bolognesi.gmail.com
I'm also working with Eclipse 3.3.2, the latest WTP, Tomcat 6.0.14, Axis2
1.4, Java 5 and I get the same error.
I did find the jar containing the missing class in the axis lib folder and
I copied it down into the project lib folder manually. This means all the
jsps compile correctly, but when I deploy I still get no joy.
Did either of you solve the problem?
also, do you know if the webtools can be used with tomcat 5 and java 1.4
