Eclipse Community ForumsEclipse can't find TLD in build path
https://www.eclipse.org/forums/index.php/mv/msg/66712/209483/#msg_209483
jars. I copied the sample JSP into WebContent, and I copied the framework
jars into WebContent/WEB-INF/lib. However, inside the JSP, it complains
that it can't find the tld for the given taglib URI. I verified that the
TLD contained in the jar file in WEB-INF/lib has a URI that matches the
URI from the taglib directive. What else could I be doing wrong?]]>David M. Karr2008-03-04T16:34:20-00:00Re: Eclipse can't find TLD in build path
https://www.eclipse.org/forums/index.php/mv/msg/66712/209551/#msg_209551
> I'm assembling a dynamic web app from some sample JSP and some framework
> framework jars into WebContent/WEB-INF/lib. However, inside the JSP, it
> complains that it can't find the tld for the given taglib URI. I
> verified that the TLD contained in the jar file in WEB-INF/lib has a URI
> that matches the URI from the taglib directive. What else could I be
> doing wrong?
You've probably just run into a problem with the order in which you
did things. Revalidating the JSP should clear the validation
error--the first time it was validated the jars weren't in place.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational]]>Nitin Dahyabhai2008-03-04T20:23:43-00:00
