Eclipse Community Forums(Solved)The solution for the conflict when Config Glassfish 4 with the Kepler on MAC OS X 10.9.1
https://www.eclipse.org/forums/index.php/mv/msg/642055/1237336/#msg_1237336
The software environment of my MAC is:
OS: MAC OS X 10.9.1
Language: English
JRE: 1.7.0_10
Eclipse: Kepler SR1
Glassfish: 4.0(open source)
The Glassfish was installed from the Eclipse Marketplace, the installation process was smoothed, and I set the admin password for the default domain--domain1. Some guys said, the password shall be left with blank, my experience is no matter, you can set it in the installation process.
When you finish the installation of Glassfish, you shall perform some operations as below:
To the menu line, click "Eclipse"-->"Preferences"
Choose "Remote System"-->"Passwords"
When you see the windows of "Passwords", click "Add".
Input relative info as upper picture and click "OK" and quit the "Preferences"
Until now, try it again, I assume the trouble has been removed.
If you cannot achieve the same result, please let me know, I would like to help you to find the answer.
