Eclipse Community Forums"make" "bash" is not found in PATH
https://www.eclipse.org/forums/index.php/mv/msg/631517/1224610/#msg_1224610
Actually I am setting Cocos2d-x for windows ... When i load and run .cpp project in Eclipse it gives me this error ...]]>Waqas Majeed2013-12-27T08:05:22-00:00Re: "make" "bash" is not found in PATH
https://www.eclipse.org/forums/index.php/mv/msg/631517/1273753/#msg_1273753
finally found it.
open Eclipse.
go to Window->Preferences
go to C/C++->New CDT Project Wizard->Makefile Project
check "Cygwin PE Parser" and "GNU Elf Parser"
in both manually set the path to those commands you see below each one.
for example select "Cygwin PE Parser" and click Browse button of the "cygpath command" and find cygpath.exe file inside "bin" folder of the cygwin.
mine is like this: "C:\Users\MDP\Cygwin\bin\cygpath.exe"
do the same thing for all of them. and click apply then ok.
remove your project and add it again. you won't get these errors anymore:
program "make" is not found in path
Program "bash" not found in PATH
]]>Mohammad Davari2014-03-20T13:46:40-00:00
