Eclipse Community Forumsserver launch configuration, classpath user entries work?
https://www.eclipse.org/forums/index.php/mv/msg/60669/191633/#msg_191633
Originally posted by: jacek.pospychala.pl.ibm.com
I have some problems with running a web application A on WebLogic. It
requires my another project B so i add it to server launch configuration
(in user entries), but this project B is not sent to the server.
How should I set the project B to be uploaded to the server? It contains
some libraries shared among other web apps so has to be uploaded to a
user entries classpath, and not be included in web application.
Any suggestions appreciated!
Jacek]]>2007-04-19T15:16:46-00:00Re: server launch configuration, classpath user entries work?
https://www.eclipse.org/forums/index.php/mv/msg/60669/191643/#msg_191643
Editing that launch configuration classpath is not going to help you in this
context (the generic WLS servers are launched as a separate process via
startWeblogic.* and the classpath for that JVM is set in the script).
You normally want to express such dependencies via the "J2EE Module
Dependencies" properties page (for a standalone web project, these
dependencies will placed the JAR for the referenced project in the
WEB-INF/lib dir of the project).
If you want a single copy of this WAR/JAR/EAR shared by multiple modules on
WLS, then you can investigate the shared library feature of WLS (see the WLS
docs for more information)
-Rob
"Jacek Pospychala" <jacek.pospychala@pl.ibm.com> wrote in message
news:f08179$eu0$1@build.eclipse.org...
> Hello,
> some libraries shared among other web apps so has to be uploaded to a user
> Jacek]]>Rob Frost2007-04-19T18:16:36-00:00Re: server launch configuration, classpath user entries work?
https://www.eclipse.org/forums/index.php/mv/msg/60669/191668/#msg_191668
Thanks Rob!
do you think the shared library feature is stable/straight enough among
different versions of WLS (8,9,9.2) that it could be put right in the
launch configuration GUI, so others wouldn't have to bother themselves
reading docs? :)
Unfortunately i am not an expert in configuring WLS...
Rob Frost wrote:
> Hi Jacek,
> -Rob
>> Hello,
>> Jacek
>]]>2007-04-20T08:37:20-00:00Log4j.properties deployment
https://www.eclipse.org/forums/index.php/mv/msg/60669/191676/#msg_191676
I need to have Log4j.properties file in "classes" directory of resulting
WAR file. How to configure that?
news:f09u6e$tsr$1@build.eclipse.org...
> Thanks Rob!
> reading docs? :)
> Rob Frost wrote:
>> Hi Jacek,
>> this context (the generic WLS servers are launched as a separate process
>> via startWeblogic.* and the classpath for that JVM is set in the script).
>> on WLS, then you can investigate the shared library feature of WLS (see
>> the WLS docs for more information)
>> -Rob
>>> Hello,
>>> Jacek
>>]]>Rob Frost2007-04-20T14:18:47-00:00
