Eclipse Community ForumsExcel as a data source
https://www.eclipse.org/forums/index.php/mv/msg/571404/1159718/#msg_1159718
Would it be beneficial to make a plug-in that could do this? Like for instance when you right click on the excel data source using BIRT that maybe could click "preview" and it would pull in the first 50 rows.
Any help would be appreciated, I have been racking my brain on this for the past couple of days.]]>Ben Burkett2013-10-28T18:47:08-00:00Re: Excel as a data source
https://www.eclipse.org/forums/index.php/mv/msg/571404/1171442/#msg_1171442
Apache POI - the Java API for Microsoft Documents, is an open source for java that can read excel sheet and then you can work on that data as you wish i.e. fill that information in the database.
Hope this reply is helpful for you TechknowHeights]]>Arnav Kumar2013-11-05T08:29:14-00:00
