Eclipse Community ForumsError while launching command: gdb --version
https://www.eclipse.org/forums/index.php/mv/msg/567143/1155311/#msg_1155311
If I change the path to the debugger it will run but it skips lines and "step over" doesnt seem to work all the time.
If I type the same into the console I get this:
jlahowetz2@snr-1770 /usr/bin $ gdb --version
GNU gdb (Ubuntu/Linaro 7.4-2012.04-0ubuntu2.1) 7.4-2012.04
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
For bug reporting instructions, please see:
I'm using Eclipse Kepler
]]>Jamie Lahowetz2013-10-25T21:02:38-00:00Re: Error while launching command: gdb --version
https://www.eclipse.org/forums/index.php/mv/msg/567143/1202600/#msg_1202600
I'm also getting the following error while launching the debugger.
Please help if anybody knows the solution.
-ben]]>Ben Alex2013-11-22T08:13:27-00:00Re: Error while launching command: gdb --version
https://www.eclipse.org/forums/index.php/mv/msg/567143/1207011/#msg_1207011
The only difference is that I am using Eclipse on a Mac OS X 10.9
I can run programs normally, but whenever I try to debug them I get this message: error while launching command: gdb --version.
If I try to run that command from terminal it states that the command could not be found, but i can see all the gdb settings on Eclipse so It should be installed. ]]>Matteo Olivi2013-11-24T10:36:32-00:00Re: Error while launching command: gdb --version
https://www.eclipse.org/forums/index.php/mv/msg/567143/1209023/#msg_1209023
If the command
gdb -version
does not work from your command line, it means wither gdb is not installed at all, or it is not part of the your PATH. You have to make it work from the command-line first if you hope to use Eclipse to debug.
Marc]]>Marc Khouzam2013-11-25T09:49:21-00:00Re: Error while launching command: gdb --version
https://www.eclipse.org/forums/index.php/mv/msg/567143/1212057/#msg_1212057
Sean Quallen2013-11-26T18:54:46-00:00Re: Error while launching command: gdb --version
https://www.eclipse.org/forums/index.php/mv/msg/567143/1219077/#msg_1219077
$ gdb --version
GNU gdb (GDB) 7.6.50.20130728-cvs (cygwin-special)
Copyright (C) 2013 Free Software Foundation, Inc.
So I don't think its an issue with installation. may be the path ???]]>Ben Alex2013-12-01T05:27:34-00:00
