Eclipse Community ForumsMany Save Conflicts
https://www.eclipse.org/forums/index.php/mv/msg/5555/16684/#msg_16684
Originally posted by: j.craig.aggiemail.usu.edu
Using RSE to edit remote files, I've been getting "Save Conflict" dialogs
on nearly every save. It is asking if I want to "Replace contents of
editor with remote file", "Overwrite the remote file", or "Save the
contents of the editor to a different remote file". I have been
overwriting because I know no one else is editing these files.
I haven't seen this happen until I recently upgraded to TM 2.0.2.
Is this a bug, or is there some other issue that may be at work here?
thanks,
--Jason]]>2007-12-11T00:14:43-00:00Re: Many Save Conflicts
https://www.eclipse.org/forums/index.php/mv/msg/5555/16734/#msg_16734
this sounds like a bug - please file a bugzilla entry for it.
Please include information like
- What connection type do you use (ssh, dstore, ...)
- What kind of remote system?
- Do you use RSE directly or through the EFS integration?
It looks like RSE doesn't get the timestamp of the remote file
right. It might help comparing the timestamp in the RSE properties
view against the actual timestamp as seen when doing "ls -l"
in a remote shell against the timestamp of the cached file in
RemoteSystemsTempFiles/...
> dialogs on nearly every save. It is asking if I want to "Replace
> contents of editor with remote file", "Overwrite the remote file", or
> "Save the contents of the editor to a different remote file". I have
> been overwriting because I know no one else is editing these files.
> thanks,
> --Jason
>]]>Martin Oberhuber2007-12-11T18:25:24-00:00Re: Many Save Conflicts
https://www.eclipse.org/forums/index.php/mv/msg/5555/571300/#msg_571300
> thanks,
> --Jason
https://www.eclipse.org/forums/index.php/mv/msg/5555/16739/#msg_16739
when you have some EFS links open, your bug might be related to https://bugs.eclipse.org/bugs/show_bug.cgi?id=205822
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member http://www.eclipse.org/dsdp/tm]]>Martin Oberhuber2007-12-11T18:37:45-00:00Re: Many Save Conflicts
https://www.eclipse.org/forums/index.php/mv/msg/5555/571312/#msg_571312
Martin Oberhuber
https://www.eclipse.org/forums/index.php/mv/msg/5555/571397/#msg_571397
then double-clicking it to edit it remotely. This isn't using EFS, right?
The file modification times show up the same in the RSE properties and
with ls -l.
--Jason]]>Jason Craig2007-12-11T22:15:26-00:00Re: Many Save Conflicts
https://www.eclipse.org/forums/index.php/mv/msg/5555/16744/#msg_16744
I'm using the RSE itself to browse a Linux system with FTP for a file, and
with ls -l.
> and then double-clicking it to edit it remotely. This isn't using EFS,
> right? The file modification times show up the same in the RSE
> properties and with ls -l.
> --Jason
> --Jason
Martin Oberhuber
Wind River Systems, Inc.
Target Management Project Lead, DSDP PMC Member http://www.eclipse.org/dsdp/tm]]>Martin Oberhuber2007-12-18T09:00:06-00:00
