Eclipse Community ForumsError 1053 when starting as Windows Service
https://www.eclipse.org/forums/index.php/mv/msg/549958/1136933/#msg_1136933
I have a weired problem with Eclipse Hudson 3.1.0 installed on my Windows 8 R2 Standard server: I have Hudson installed as a Windows service. When I stop and start it a couple of seconds later, from time to time, the following error is thrown and Hudson does not start:
"Windows could not start the Hudson Buildserver service on [my server host name]. Error 1053: The service did not respond to the start or control request in a timely fashion."
As I said, this happens only from time to time, but definitely way to often. Once it happens, only uninstalling and installing the service helps. Sometimes even a reboot of the entire machine is required.
Do you have any hint about this problem?
Thanks a lot.
Timo]]>Timo Rohrberg2013-10-14T06:42:51-00:00Re: Error 1053 when starting as Windows Service
https://www.eclipse.org/forums/index.php/mv/msg/549958/1139217/#msg_1139217
Could you please check your event log on Windows to see if any errors have been reported. On Windows 7, open the Control Panel. Open the Administrative Tools group and open the Event Viewer. Please check the Application logs for any output from the Hudson service.
Could you post errors if any any?
Thanks.
Latha Amujuri]]>Latha Amujuri2013-10-15T16:15:49-00:00Re: Error 1053 when starting as Windows Service
https://www.eclipse.org/forums/index.php/mv/msg/549958/1141821/#msg_1141821
I checked the Windows event log and unfortunately, there are no logs at all from Hudson if it fails to start as described. It logs successful starting and stopping, but nothing if it fails .
Do you have any further hints? This is definitively an annoying "feature"
Timo]]>Timo Rohrberg2013-10-17T08:01:06-00:00Re: Error 1053 when starting as Windows Service
https://www.eclipse.org/forums/index.php/mv/msg/549958/1142120/#msg_1142120
I have checked the Windows event log and unfortunately, there are no logs if Hudson did not startup successfully. It logs starting and stopping if everything works, but not in the error case described above .
Do you have any further hints.
Timo]]>Timo Rohrberg2013-10-17T12:04:09-00:00Re: Error 1053 when starting as Windows Service
https://www.eclipse.org/forums/index.php/mv/msg/549958/1142121/#msg_1142121
I have checked the Windows event log and unfortunately there are no logs in case of a failed Hudson startup. It logs starting and stopping if it works, but not in the error case described above .
Do you have any further hints? This is a quite annoying issue...
Timo Rohrberg]]>Timo Rohrberg2013-10-17T12:05:49-00:00Re: Error 1053 when starting as Windows Service
https://www.eclipse.org/forums/index.php/mv/msg/549958/1142220/#msg_1142220
thanks for the hint. I have checked the Windows event log, but unfortunately, there are no entries from Hudson in case it fails to startup. It nicely logs starting and shutdown if everything works, but in case of the error described above, there's no log entry at all.
Timo Rohrberg]]>Timo Rohrberg2013-10-17T13:22:56-00:00Re: Error 1053 when starting as Windows Service
https://www.eclipse.org/forums/index.php/mv/msg/549958/1143439/#msg_1143439
I'm sorry, that my last posting occured serveral times. The problem was that it did not show up whenever I tried to post it yesterday, so I tried several times.
Timo]]>Timo Rohrberg2013-10-18T07:25:55-00:00Re: Error 1053 when starting as Windows Service
https://www.eclipse.org/forums/index.php/mv/msg/549958/1144084/#msg_1144084
Thanks.
Latha]]>Latha Amujuri2013-10-18T16:34:49-00:00Re: Error 1053 when starting as Windows Service
https://www.eclipse.org/forums/index.php/mv/msg/549958/1159516/#msg_1159516
sorry for the delay... I have been busy with different stuff the past days...
Well, unfortunately, I cannot give you that many information about my setup as I simply don't know what could cause the problem. What do you mean with "security enabled"? Also - to my knowledge - there is nothing specific that triggers that failure. It just happens quite often when I stop the service and try to start it again. I tried different things already, such as waiting a couple of minutes between shutdown and and subsequent startup - it did not help specificially. Whenever the failure occurs, the only thing that definitely helps is to uninstall the service, reboot the complete machine, reinstall the service and start it... and this is quite unsatisfiable as you can imagine. Maybe one thing to note is that when uninstalling the service in that situation it switches to "disabled" in most cases, instead of disappearing from the services panel completely.
Any further hints are much appreciated!
Thanks for your help so far.
Best regards
Timo]]>Timo Rohrberg2013-10-28T15:43:02-00:00Re: Error 1053 when starting as Windows Service
https://www.eclipse.org/forums/index.php/mv/msg/549958/1236467/#msg_1236467
I've got the same problem preceding by following warning :
Log Name: Application
Source: Microsoft-Windows-User Profiles Service
Date: 27.01.2014 09:03:39
Event ID: 1530
Task Category: None
Level: Warning
Keywords:
User: SYSTEM
Computer: ssva90004.svanet.ch
Description:
Windows detected your registry file is still in use by other applications or services. The file will be unloaded now. The applications or services that hold your registry file may not function properly afterwards.
DETAIL -
15 user registry handles leaked from \Registry\User\S-1-5-21-2796727953-1827113128-673018136-1027:
Process 3320 (\Device\HarddiskVolume2\Java\Hudson\hudson.exe) has opened key \REGISTRY\USER\S-1-5-21-2796727953-1827113128-673018136-1027
Process 3320 (\Device\HarddiskVolume2\Java\Hudson\hudson.exe) has opened key \REGISTRY\USER\S-1-5-21-2796727953-1827113128-673018136-1027\Software\Microsoft\SystemCertificates\trust
Process 3320 (\Device\HarddiskVolume2\Java\Hudson\hudson.exe) has opened key \REGISTRY\USER\S-1-5-21-2796727953-1827113128-673018136-1027\Software\Microsoft\SystemCertificates\SmartCardRoot
Process 3320 (\Device\HarddiskVolume2\Java\Hudson\hudson.exe) has opened key \REGISTRY\USER\S-1-5-21-2796727953-1827113128-673018136-1027\Control Panel\International
Process 3320 (\Device\HarddiskVolume2\Java\Hudson\hudson.exe) has opened key \REGISTRY\USER\S-1-5-21-2796727953-1827113128-673018136-1027\Software\Microsoft\SystemCertificates\Disallowed
Process 3320 (\Device\HarddiskVolume2\Java\Hudson\hudson.exe) has opened key \REGISTRY\USER\S-1-5-21-2796727953-1827113128-673018136-1027\Software\Microsoft\SystemCertificates\My
Process 3320 (\Device\HarddiskVolume2\Java\Hudson\hudson.exe) has opened key \REGISTRY\USER\S-1-5-21-2796727953-1827113128-673018136-1027\Software\Microsoft\Windows\CurrentVersion\Explorer
Process 3320 (\Device\HarddiskVolume2\Java\Hudson\hudson.exe) has opened key \REGISTRY\USER\S-1-5-21-2796727953-1827113128-673018136-1027\Software\Microsoft\SystemCertificates\CA
Process 3320 (\Device\HarddiskVolume2\Java\Hudson\hudson.exe) has opened key \REGISTRY\USER\S-1-5-21-2796727953-1827113128-673018136-1027\Software\Microsoft\SystemCertificates\TrustedPeople
Process 3320 (\Device\HarddiskVolume2\Java\Hudson\hudson.exe) has opened key \REGISTRY\USER\S-1-5-21-2796727953-1827113128-673018136-1027\Software\Policies\Microsoft\SystemCertificates
Process 3320 (\Device\HarddiskVolume2\Java\Hudson\hudson.exe) has opened key \REGISTRY\USER\S-1-5-21-2796727953-1827113128-673018136-1027\Software\Microsoft\SystemCertificates\Root
Do you have any idea why this happens?
Thanks a lot.
Best regards
Niki]]>Nikoletta Gautschi2014-01-27T09:29:31-00:00
