Eclipse Community ForumsEdapt on Kepler, contribution doesn't show.
https://www.eclipse.org/forums/index.php/mv/msg/526258/1110884/#msg_1110884
I am moving the Edapt project to Kepler.
The following definition doesn't show in a View when installing on a
Kepler release of Eclipse. Any idea why?
locationURI="toolbar:org.eclipse.emf.edapt.history.instantiation.view.operationsBrowser">
<command
commandId="org.eclipse.emf.edapt.CreateHistory"
style="push">
</command>
<command
commandId="org.eclipse.emf.edapt.Release"
style="push">
</command>
<command
commandId="org.eclipse.emf.edapt.Converge"
style="push">
</command>
</menuContribution>
</extension>]]>Christophe Bouhier2013-09-17T13:00:45-00:00Re: Edapt on Kepler, contribution doesn't show.
https://www.eclipse.org/forums/index.php/mv/msg/526258/1112838/#msg_1112838
are you migrating to Kepler compatibility mode or native e4?
Jonas
Am 17.09.2013 15:00, schrieb Christophe Bouhier:
> Rgds Christophe
> <extension
> point="org.eclipse.ui.menus">
> <menuContribution
> <command
> style="push">
> </command>
> <command
> style="push">
> </command>
> <command
> style="push">
> </command>
> </menuContribution>
> </extension>
>]]>Jonas Helming2013-09-20T08:36:09-00:00Re: Edapt on Kepler, contribution doesn't show.
https://www.eclipse.org/forums/index.php/mv/msg/526258/1112961/#msg_1112961
It's compat. as we build plugins for the Kepler IDE. As far as I am
aware, mix mode is not really supported/easy/... yet.
> Regards
> Jonas
>> Hi,
>> Rgds Christophe
>> <extension
>> <menuContribution
>> <command
>> style="push">
>> </command>
>> <command
>> style="push">
>> </command>
>> <command
>> style="push">
>> </command>
>> </menuContribution>
>> </extension>
>]]>Christophe Bouhier2013-09-20T12:35:37-00:00Re: Edapt on Kepler, contribution doesn't show.
https://www.eclipse.org/forums/index.php/mv/msg/526258/1393987/#msg_1393987
I am experiencing the same problem, dispite the bug report saying it's fixed.
I assume the installation of edapt on my eclipse doesn't have this fix yet.
Is it likely to occure some maintenance operations on this project in the future?
Tanks!
]]>jpfse 2014-07-04T15:39:42-00:00Re: Edapt on Kepler, contribution doesn't show.
https://www.eclipse.org/forums/index.php/mv/msg/526258/1395846/#msg_1395846
> Hello!
> fixed.
> My assumption is based on the fact that the edapt update site on the
> Download page is not maintained:
> https://www.eclipse.org/edapt/download.php
> The other two links dont work.
> the future?
Yes, I do but limited. The edapt builds always contain a repo you can
use. Please check here:
