Eclipse Community Forums3.0.1 debian hudson doesn't show up in web browser
https://www.eclipse.org/forums/index.php/mv/msg/513973/1096811/#msg_1096811
I'm running hudson 3.0.1 debian package on an amd64 machine. It seemed to install fine, but when I try to bring it up in a browser with an "localhost:8080/hudson", I get a:
HTTP ERROR 404
Problem accessing /hudson. Reason:
Not Found
I've tried it running as other users (hudson, root) but the same thing appears. When I perform a 'ps -ef | grep hudson' and everything looks ok.
any reason why it's not showing up on the web browser?
o not installed properly?
o permission problems?]]>S Morehouse2013-08-28T22:34:19-00:00Re: 3.0.1 debian hudson doesn't show up in web browser
https://www.eclipse.org/forums/index.php/mv/msg/513973/1097435/#msg_1097435
Winston Prakash2013-08-29T18:21:32-00:00Re: 3.0.1 debian hudson doesn't show up in web browser
https://www.eclipse.org/forums/index.php/mv/msg/513973/1097445/#msg_1097445
I see it says to run it like that here: http://wiki.eclipse.org/Starting_and_Accessing_Hudson
I remember somewhere where it said to run it with / hudson. Maybe if you run it with apache. I'll note it here if I find it.
Thanks]]>S Morehouse2013-08-29T18:39:40-00:00Re: 3.0.1 debian hudson doesn't show up in web browser
https://www.eclipse.org/forums/index.php/mv/msg/513973/1097504/#msg_1097504
If you install in Apache Tomcat, then it adds the context "hudson" (depending on war name or the context path specified in Tomcat Manager). In that case you have to use the context path as http:// localhost:8080/hudson.
Also you can run Hudson using java -jar hudson.war --prefix hudson. In that case also you have to use http:// localhost:8080/hudson]]>Winston Prakash2013-08-29T20:33:27-00:00
