Eclipse Community ForumsWSDL Editor extension points
https://www.eclipse.org/forums/index.php/mv/msg/50474/161753/#msg_161753
Editor (i.e. are they going to become API in WTP1.5 or are they going to
remain internal and we use them at our own discretion).
Mihnea]]>Mihnea Galeteanu2006-02-23T16:20:27-00:00Re: WSDL Editor extension points
https://www.eclipse.org/forums/index.php/mv/msg/50474/162829/#msg_162829
It will be a little while before we're comfortable with the extension
point design. I'd encourage anyone who's interested in extending the WSDL
editor to post here and describe your requirements. Mockups and screen
shots would be handy too.
Use the existing extension points at your own risk they'll very likely
change in the near future. If you can provide information regarding how
you're intending to extenend we'll be able to plan future changes with
your usage in mind... and make your life easier when things do change.
thanks
craig]]>Craig Salter2006-03-05T00:46:35-00:00Re: WSDL Editor extension points
https://www.eclipse.org/forums/index.php/mv/msg/50474/546209/#msg_546209
I am currently developing an extension to the wsdl editor to add feature with which user can add partnerlinktype, property and propertyalias in the wsdl in context with BPEL.
Is there any possibility to add custom controls instead of text / combo. Also i want add a listener in the text box so that i can perform operation when user is typing a type/element in the text box manually.
