Error.DesignFileException.SYNTAX_ERROR - 19 errors found! 1.) ( line = 4911, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 2.) ( line = 4917, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 3.) ( line = 4923, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 4.) ( line = 4930, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 5.) ( line = 4936, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 6.) ( line = 4937, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 7.) ( line = 4938, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 8.) ( line = 4945, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 9.) ( line = 4946, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 10.) ( line = 4947, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 11.) ( line = 4948, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 12.) ( line = 4955, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 13.) ( line = 4956, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 14.) ( line = 4957, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 15.) ( line = 4958, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 16.) ( line = 4965, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 17.) ( line = 4972, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 18.) ( line = 4979, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.) 19.) ( line = 4986, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[0] is full.)
26 juil. 2013 10:44:51 org.eclipse.birt.report.model.parser.ModuleReader readModule GRAVE: Line Number:4555 Error Code:Error.XMLParserException.EXCEPTION Exception:org.eclipse.birt.report.model.api.command.ContentException: The slot(header) of the report.Body[2] is full. Message:A generic exception occurred. 26 juil. 2013 10:44:51 org.eclipse.birt.report.engine.api.impl.ReportEngineHelper getReportDesignHandle GRAVE: invalid design file file:/C:/Users/[b]totot[/b]/workspace/.metadata/.plugins/org.eclipse.wst.server.core/tmp0/wtpwebapps/ControleInterneV4/reports/restitParEntreprise.rptdesign org.eclipse.birt.report.engine.api.EngineException: The design file file:/C:/Users/toto.VEDOM1/workspace/.metadata/.plugins/org.eclipse.wst.server.core/tmp0/wtpwebapps/ControleInterneV4/reports/restitParEntreprise.rptdesign has error and can not be run. at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:260) at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:274) at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:196) at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:130) at org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:310) at com.toto.ci.struts.action.ReportAction.genereRapport(ReportAction.java:120) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at com.opensymphony.xwork2.DefaultActionInvocation.invokeAction(DefaultActionInvocation.java:441) at com.opensymphony.xwork2.DefaultActionInvocation.invokeActionOnly(DefaultActionInvocation.java:280) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:243) at com.opensymphony.xwork2.interceptor.DefaultWorkflowInterceptor.doIntercept(DefaultWorkflowInterceptor.java:165) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:87) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at com.opensymphony.xwork2.validator.ValidationInterceptor.doIntercept(ValidationInterceptor.java:252) at org.apache.struts2.interceptor.validation.AnnotationValidationInterceptor.doIntercept(AnnotationValidationInterceptor.java:68) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:87) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at com.opensymphony.xwork2.interceptor.ConversionErrorInterceptor.intercept(ConversionErrorInterceptor.java:122) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at com.opensymphony.xwork2.interceptor.ParametersInterceptor.doIntercept(ParametersInterceptor.java:195) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:87) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at com.opensymphony.xwork2.interceptor.ParametersInterceptor.doIntercept(ParametersInterceptor.java:195) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:87) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at com.opensymphony.xwork2.interceptor.StaticParametersInterceptor.intercept(StaticParametersInterceptor.java:179) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at org.apache.struts2.interceptor.MultiselectInterceptor.intercept(MultiselectInterceptor.java:75) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at org.apache.struts2.interceptor.CheckboxInterceptor.intercept(CheckboxInterceptor.java:94) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at org.apache.struts2.interceptor.FileUploadInterceptor.intercept(FileUploadInterceptor.java:235) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at com.opensymphony.xwork2.interceptor.ModelDrivenInterceptor.intercept(ModelDrivenInterceptor.java:89) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at com.opensymphony.xwork2.interceptor.ScopedModelDrivenInterceptor.intercept(ScopedModelDrivenInterceptor.java:130) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at org.apache.struts2.interceptor.debugging.DebuggingInterceptor.intercept(DebuggingInterceptor.java:267) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at com.opensymphony.xwork2.interceptor.ChainingInterceptor.intercept(ChainingInterceptor.java:126) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at com.opensymphony.xwork2.interceptor.PrepareInterceptor.doIntercept(PrepareInterceptor.java:138) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:87) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at com.opensymphony.xwork2.interceptor.I18nInterceptor.intercept(I18nInterceptor.java:165) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at org.apache.struts2.interceptor.ServletConfigInterceptor.intercept(ServletConfigInterceptor.java:164) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at com.opensymphony.xwork2.interceptor.AliasInterceptor.intercept(AliasInterceptor.java:179) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at com.opensymphony.xwork2.interceptor.ExceptionMappingInterceptor.intercept(ExceptionMappingInterceptor.java:176) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at com.toto.ci.struts.interceptors.totoValidationInterceptor.intercept(totoValidationInterceptor.java:20) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:237) at org.apache.struts2.impl.StrutsActionProxy.execute(StrutsActionProxy.java:52) at org.apache.struts2.dispatcher.Dispatcher.serviceAction(Dispatcher.java:488) at org.apache.struts2.dispatcher.FilterDispatcher.doFilter(FilterDispatcher.java:395) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.toto.ci.filter.UserFilter.doFilter(UserFilter.java:37) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.toto.utils.ActionMessageUtils.doFilter(ActionMessageUtils.java:50) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.toto.ci.filter.AuthenticationFilter.doFilter(AuthenticationFilter.java:71) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at fr.smile.hibernate.HibernateFilter.doFilter(HibernateFilter.java:56) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at fr.smile.bench.BenchFilter.doFilter(BenchFilter.java:36) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.toto.ci.filter.ExceptionFilter.doFilter(ExceptionFilter.java:24) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857) at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588) at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489) at java.lang.Thread.run(Unknown Source) Caused by: Error.DesignFileException.SYNTAX_ERROR - 1 errors found! 1.) ( line = 4555, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.ContentException (code = Error.ContentException.SLOT_IS_FULL, message : The slot(header) of the report.Body[2] is full.) at org.eclipse.birt.report.model.parser.ModuleParserHandler.doEndDocument(ModuleParserHandler.java:348) at org.eclipse.birt.report.model.parser.ModuleParserHandler.endDocument(ModuleParserHandler.java:278) at org.apache.xerces.parsers.AbstractSAXParser.endDocument(Unknown Source) at org.apache.xerces.impl.XMLDocumentScannerImpl.endEntity(Unknown Source) at org.apache.xerces.impl.XMLEntityManager.endEntity(Unknown Source) at org.apache.xerces.impl.XMLEntityScanner.load(Unknown Source) at org.apache.xerces.impl.XMLEntityScanner.skipSpaces(Unknown Source) at org.apache.xerces.impl.XMLDocumentScannerImpl$TrailingMiscDispatcher.dispatch(Unknown Source) at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source) at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source) at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source) at org.apache.xerces.parsers.XMLParser.parse(Unknown Source) at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source) at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source) at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source) at org.eclipse.birt.report.model.parser.ModuleReader.readModule(ModuleReader.java:97) at org.eclipse.birt.report.model.parser.DesignReader.read(DesignReader.java:88) at org.eclipse.birt.report.model.core.DesignSessionImpl.openDesign(DesignSessionImpl.java:315) at org.eclipse.birt.report.model.api.SessionHandleImpl.openDesign(SessionHandleImpl.java:294) at org.eclipse.birt.report.engine.parser.ReportParser.getDesignHandle(ReportParser.java:158) at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:255) ... 89 more [26 juil. 2013 10:44:51 - controle-interne] DEBUG (BenchFilter.java:39) - Bench filter : Total : 21984 ms [/controle-interne/rapport/genereRapport.action][null]
