Eclipse Community Forumspopulate textbox when radio button selected
https://www.eclipse.org/forums/index.php/mv/msg/489076/1063845/#msg_1063845
how to populate textbox when radio button selected and i have to pass some text in text box and it have to get result of parameter for charts
for example
i )country is Radio button if i select then TextBox have to populate in that i will pass a "india" so it have to produce a total sale of that country
ii)City is Radio button if i select then TextBox have to populate in that i will pass a "Tamil nadu" so it have to produce a total sale of that City
and then while i enter some text in text box it have to auto search a word in it....
so can u provide a solution for this by correcting my report
thank u in advance]]>4040 40402013-06-14T13:09:27-00:00Re: populate textbox when radio button selected
https://www.eclipse.org/forums/index.php/mv/msg/489076/1064057/#msg_1064057
can u guide for this report?
thank u in advance...........
]]>4040 40402013-06-17T13:00:59-00:00Re: populate textbox when radio button selected
https://www.eclipse.org/forums/index.php/mv/msg/489076/1064393/#msg_1064393
Michael Williams2013-06-19T05:19:34-00:00Re: populate textbox when radio button selected
https://www.eclipse.org/forums/index.php/mv/msg/489076/1064577/#msg_1064577
]]>4040 40402013-06-20T04:21:18-00:00Re: populate textbox when radio button selected
https://www.eclipse.org/forums/index.php/mv/msg/489076/1064670/#msg_1064670
for example :
one set of radio button and populate a list box or text box
item wise ---->A,B,C,D,E
main type---->A,b,c,d
another set of radio button and populate a list box or text box
country-->A,B,C,D,E
city---->A,B,C,D,E
if i select A From ITEM WISE and then I select B from COUNTRY result will be produced
and then again if i select A From ITEM WISE and then I select B from city result will be produced----
i have thought to pass parameter by url or by on click event but am struggling a lot
my question is how to pass parameter for this report in custom parameter page to hide/show the appropriate one based on the radio button value.
can u provide solution for this by correcting my jsp
thank u in advance
]]>4040 40402013-06-20T13:29:01-00:00Re: populate textbox when radio button selected
https://www.eclipse.org/forums/index.php/mv/msg/489076/1064984/#msg_1064984
4040 40402013-06-22T14:28:48-00:00Re: populate textbox when radio button selected
https://www.eclipse.org/forums/index.php/mv/msg/489076/1065663/#msg_1065663
Michael Williams2013-06-27T05:09:28-00:00Re: populate textbox when radio button selected
https://www.eclipse.org/forums/index.php/mv/msg/489076/1065799/#msg_1065799
Or are you looking for a sample that would show something like, if you click on the city radio button that the country parameter is disabled and if you click the country option, the city parameter is disabled? Let me know.]]>Michael Williams2013-06-27T14:07:17-00:00Re: populate textbox when radio button selected
https://www.eclipse.org/forums/index.php/mv/msg/489076/1065869/#msg_1065869
i)item type, ii)main group, iii)sub group---as first separate parameter group
and then i have
i)Country ii) state iii) city ---> as second separate parameter group
suppose A)if i have to select a Radio button item type and then i can randomly select any Radio button from second separate parameter group result will be produce according to it..
B)if i have to select a Radio button main group and then i can randomly select any Radio button from second separate parameter group result will be produce according to it...
my query is :
SELECT distinct to_char(TRAN_DATE,'mm') as month,
TRAN_DATE,COUNTRY_NAME ,ZONE_NAME,STATE_NAME,CITY_NAME,area_manager,OUTLET_NAME,
GROUP_name,
SUB_GROUP_name,
ITEM_NAME,
sum(qty),sum(AMOUNT)
FROM OUTLET_ITEMWISE_FACT_BACK A,OUTLET_DETAILS B,WEB_ITEM_MASTER C
WHERE
A.OUTLET_ID=B.OUTLET_ID AND
A.ITEM_CODE=C.ITEM_CODE
group by COUNTRY_NAME,ZONE_NAME,STATE_NAME,CITY_NAME,OUTLET_NAME,ITEM_NAME,
SUB_GROUP_name,GROUP_name,area_manager,TRAN_DATE
so my question how can i Design the report and how to pass parameter in report
and how can i call in jsp....am struggling a lot for this report..
kindly provide sample report and jsp for this ..... at least for one option..
thank in advance]]>4040 40402013-06-28T05:01:51-00:00Re: populate textbox when radio button selected
https://www.eclipse.org/forums/index.php/mv/msg/489076/1067048/#msg_1067048
Michael Williams2013-07-05T15:15:41-00:00Re: populate textbox when radio button selected
https://www.eclipse.org/forums/index.php/mv/msg/489076/1067386/#msg_1067386
thank u]]>4040 40402013-07-08T13:25:18-00:00Re: populate textbox when radio button selected
https://www.eclipse.org/forums/index.php/mv/msg/489076/1071242/#msg_1071242
Michael Williams2013-07-19T16:22:37-00:00
