Eclipse Community ForumsAdd my var in Quick Reference
https://www.eclipse.org/forums/index.php/mv/msg/487784/1059631/#msg_1059631
As I stated I can dynamically add variables to the Quick Reference???.. I read the Xtext Documentation in 9.4.1. Cross Reference Template Variable Resolver.. talk about variable and Quick Reference.. this is when I press Ctrl+Space???.. this is I need.. when I press Ctr+Space in my Xtext Editor the var declared show...If you do not understand my question, is that I do not speak English, but I try to learn more about this framework, sorry]]>Yoandri Saavedra2013-05-20T23:27:20-00:00Re: Add my var in Quick Reference
https://www.eclipse.org/forums/index.php/mv/msg/487784/1060693/#msg_1060693
var:
"decl" name=ValidId ;
Myrefer:
varref=[var] // This is quick reference
]]>Yoandri Saavedra2013-05-27T21:28:47-00:00Re: Add my var in Quick Reference
https://www.eclipse.org/forums/index.php/mv/msg/487784/1060707/#msg_1060707
]]>Christian Dietrich2013-05-28T07:02:25-00:00Re: Add my var in Quick Reference
https://www.eclipse.org/forums/index.php/mv/msg/487784/1060897/#msg_1060897
]]>Yoandri Saavedra2013-05-29T03:11:34-00:00
