Eclipse Community Forums[CDO] OracleAdapter and ORA-00904
https://www.eclipse.org/forums/index.php/mv/msg/486153/1053617/#msg_1053617
But struggling with this error!
jvm 1 | WrapperManager Error: Error in WrapperListener.start callback. org.eclipse.net4j.db.DBException: Problem with table cdo_lobs: SELECT id, size, bdata, cdata FROM cdo_lobs
jvm 1 | WrapperManager Error: org.eclipse.net4j.db.DBException: Problem with table cdo_lobs: SELECT id, size, bdata, cdata FROM cdo_lobs
jvm 1 | WrapperManager Error: at org.eclipse.net4j.spi.db.DBAdapter.validateTable(DBAdapter.java:447)
I'm using the code from emf-cdo-S20130319-1538 build
Is there some way to make Oracle less sensitive ?
Or is there still some problemes with the OracleAdpater ?
Børre Nordbakken
Brønnøysundregistrene]]>Børre ordbakken2013-05-06T21:19:16-00:00Re: [CDO] OracleAdapter and ORA-00904
https://www.eclipse.org/forums/index.php/mv/msg/486153/1053762/#msg_1053762
and you can expect to see a response there.
On 07/05/2013 3:06 PM, Børre ordbakken wrote:
> We are trying to get CDO running on Oracle 11g
> jvm 1 | WrapperListener_start_runner
> [org.eclipse.net4j.spi.db.DBAdapter] CREATE TABLE cdo_lobs (id
> VARCHAR2(64), size NUMBER, bdata BLOB, cdata CLOB)
> [org.eclipse.net4j.spi.db.DBAdapter] -- ORA-00904: : ugyldig
> identifikator
> jvm 1 |
> [org.eclipse.net4j.spi.db.DBAdapter] SELECT id, size, bdata, cdata
> FROM cdo_lobs
> Best regards,
> Børre Nordbakken
> Brønnøysundregistrene]]>Ed Merks2013-05-07T13:57:55-00:00
