Eclipse Community ForumsNattable tree grid
https://www.eclipse.org/forums/index.php/mv/msg/486028/1053168/#msg_1053168
I am trying to use Nattable grid in my application and I am able to use it with a dataprovider to show list of objects in the grid. The reason I am using a DataProvider is because all the columns that has to be shown are not the actual properties of the object and I control that in the getDataValue(col,row) method to provide the correct column data from the row object. Now that this works I am wondering if I can apply the same concept for a tree grid. My grid would have atleast couple of layers and I want to provide the data for the columns on both the layers the same way and not using the ReflectiveColumnAccessor. Is there an example that points me to do this?
