Eclipse Community ForumsGlitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1052857/#msg_1052857
It seems to relate with the view drawing but I can't see how to fix it. Plus it works fine on MacOs, I am experiencing this behavior on Windows 7.
In both cases I use a JSE1.6 with Juno]]>Andrea Sindico2013-04-30T18:04:43-00:00Re: Glitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1053146/#msg_1053146
As you can see when the GanttChart object is updated I see a black background with different glitches in the view containing it
]]>Andrea Sindico2013-05-02T16:42:27-00:00Re: Glitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1053163/#msg_1053163
Did you implement the setFocus method of the view?
Does it go away if you reseize the view?
Wim]]>Wim Jongman2013-05-02T19:00:20-00:00Re: Glitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1053167/#msg_1053167
I have checked the setFocus method and found a bug that might be cause of the issue. I say may because I am working on a Mac where I don't experience the problem. I have to wait tomorrow to check it.
Thank you very much for your kind help !
]]>Andrea Sindico2013-05-02T19:35:47-00:00Re: Glitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1053212/#msg_1053212
the setFocus method is implemented this way
public void setFocus() {
ganttChart.getGanttComposite().setFocus();
the problem still happens and it doesn't go away when I resize the view]]>Andrea Sindico2013-05-03T07:30:22-00:00Re: Glitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1053223/#msg_1053223
Andrea Sindico2013-05-03T08:43:34-00:00Re: Glitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1053267/#msg_1053267
The problem seems to be related with Windows 7 or with the 64 bit architecture? could this be possible?]]>Andrea Sindico2013-05-03T13:01:56-00:00Re: Glitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1053315/#msg_1053315
Could you for example:
* erase the complete gantt and rebuild it completely instead of updating.
* try the various pack and layout methods
]]>Wim Jongman2013-05-03T20:15:33-00:00Re: Glitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1053316/#msg_1053316
Wim Jongman2013-05-03T20:17:09-00:00Re: Glitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1053323/#msg_1053323
I tried to dispose and instantiate a new GanttChart but it behaves in the same way
I tried to get the parent and invoke the layout method but i did not try the pack
]]>Andrea Sindico2013-05-03T21:17:08-00:00Re: Glitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1053346/#msg_1053346
Wim]]>Wim Jongman2013-05-04T08:33:03-00:00Re: Glitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054212/#msg_1054212
I am about to open the bug. I can already tell you it seems the problem is about the GanttSection object.
Follow me on Twitter https://twitter.com/andreasindico]]>Andrea Sindico2013-05-08T08:06:08-00:00Re: Glitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1057029/#msg_1057029
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055494/#msg_1055494
https://www.eclipse.org/forums/index.php/mv/msg/485937/1056269/#msg_1056269
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054993/#msg_1054993
https://www.eclipse.org/forums/index.php/mv/msg/485937/1056017/#msg_1056017
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054739/#msg_1054739
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054487/#msg_1054487
https://www.eclipse.org/forums/index.php/mv/msg/485937/1057561/#msg_1057561
https://www.eclipse.org/forums/index.php/mv/msg/485937/1056538/#msg_1056538
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055782/#msg_1055782
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054250/#msg_1054250
https://www.eclipse.org/forums/index.php/mv/msg/485937/1056827/#msg_1056827
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055294/#msg_1055294
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054527/#msg_1054527
https://www.eclipse.org/forums/index.php/mv/msg/485937/1057343/#msg_1057343
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054786/#msg_1054786
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055049/#msg_1055049
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055564/#msg_1055564
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054287/#msg_1054287
https://www.eclipse.org/forums/index.php/mv/msg/485937/1056098/#msg_1056098
https://www.eclipse.org/forums/index.php/mv/msg/485937/1056357/#msg_1056357
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054569/#msg_1054569
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054062/#msg_1054062
I am about to open the bug. I can already tell you it seems the problem is about the GanttSection object. ]]>Andrea Sindico2013-05-08T08:06:08-00:00Re: Glitch when updating a view containing a GanttChart
https://www.eclipse.org/forums/index.php/mv/msg/485937/1057134/#msg_1057134
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054833/#msg_1054833
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055860/#msg_1055860
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054326/#msg_1054326
https://www.eclipse.org/forums/index.php/mv/msg/485937/1056633/#msg_1056633
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055360/#msg_1055360
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055109/#msg_1055109
https://www.eclipse.org/forums/index.php/mv/msg/485937/1057669/#msg_1057669
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054611/#msg_1054611
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055635/#msg_1055635
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054110/#msg_1054110
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054366/#msg_1054366
https://www.eclipse.org/forums/index.php/mv/msg/485937/1056928/#msg_1056928
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054885/#msg_1054885
https://www.eclipse.org/forums/index.php/mv/msg/485937/1057449/#msg_1057449
https://www.eclipse.org/forums/index.php/mv/msg/485937/1056183/#msg_1056183
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054141/#msg_1054141
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054654/#msg_1054654
https://www.eclipse.org/forums/index.php/mv/msg/485937/1056446/#msg_1056446
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055168/#msg_1055168
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055425/#msg_1055425
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055938/#msg_1055938
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054406/#msg_1054406
https://www.eclipse.org/forums/index.php/mv/msg/485937/1057238/#msg_1057238
https://www.eclipse.org/forums/index.php/mv/msg/485937/1056729/#msg_1056729
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054938/#msg_1054938
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055709/#msg_1055709
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054175/#msg_1054175
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054696/#msg_1054696
https://www.eclipse.org/forums/index.php/mv/msg/485937/1054446/#msg_1054446
https://www.eclipse.org/forums/index.php/mv/msg/485937/1055230/#msg_1055230
https://www.eclipse.org/forums/index.php/mv/msg/485937/1057722/#msg_1057722
it seems something went wrong with the latest post.
May you please delete the duplicate messages? I can't see how to do that]]>Andrea Sindico2013-05-08T12:59:42-00:00
