Eclipse Community ForumsTableViewer evaluation
https://www.eclipse.org/forums/index.php/mv/msg/485710/1052537/#msg_1052537
1. Grouping
2. Single and multiple selection of columns, rows and cells
3. Drag 'n Drop from and into table
4. Copy and paste from and into table
5. Coloring of text and background of columns, rows and cells
6. Column order and width change
7. Display of bitmaps in cells and column headers
8. Tooltips for cells and column headers
9. Context menu for cells and column headers]]>Nikolas Batanov2013-04-30T08:02:46-00:00Re: TableViewer evaluation
https://www.eclipse.org/forums/index.php/mv/msg/485710/1397126/#msg_1397126
you can see the widgets (from the nebula projects) XViewer and NatTable that may helps you.
