Eclipse Community ForumsWhich Java Card Dev toolkit for Eclipse juno 4.2?
https://www.eclipse.org/forums/index.php/mv/msg/452979/1008633/#msg_1008633
I have Eclipse Juno 4.2 installed and I want to have the javacard plugin for it.
I downloaded the lastest version of JCDE (java_card_kit-classic-3_0_4-rr-bin-do-b28-windows-06_sep_2011), followed all the installation steps.
But I could not found how to make that version work with Eclipse (the main problem being that no converter.jar file is present in the lib folder of the JCDE).
SO I tried the JCDE version 2.2.2, but then I got problems when trying to produce a CAP file (unsupported class file format of version 50.0.). I read somewhere that this is because the eclipse version and the JCDE version are not compatible.
This is driving me crazy and I hope someone here will be able to help...
Alexandra.]]>Alexandra Ducati-Manas2013-02-13T11:18:08-00:00Re: Which Java Card Dev toolkit for Eclipse juno 4.2?
https://www.eclipse.org/forums/index.php/mv/msg/452979/1014982/#msg_1014982
Did you resolve this? I am having the same problem.
Please share, if you managed to resolve it.
Tushar]]>Tushar Jain2013-02-27T06:48:40-00:00Re: Which Java Card Dev toolkit for Eclipse juno 4.2?
https://www.eclipse.org/forums/index.php/mv/msg/452979/1015323/#msg_1015323
Unfortunately, I have not solved my problem. I think I'll have to develop the applet code with eclipse and then try and compile a cap file using the javacard dev toolkit in standalone...
Thanks for your answer though.
Alexandra.]]>Alexandra Ducati-Manas2013-02-28T08:50:18-00:00
