Eclipse Community ForumsProperty 'ownedPort' is read-only
https://www.eclipse.org/forums/index.php/mv/msg/452394/1006495/#msg_1006495
I've defined a mapping that takes an "inout cls:Class" as argument and returns an "UML::Port". The mapping contains the following statement:
cls.ownedPort += result;
It works in IndigoSR2 but I cannot get it working in JunoSR1. I get the following error: "Property 'ownedPort' is read-only". How do I fix this issue?
Matteo]]>Matteo M.2013-01-31T14:01:16-00:00Re: Property 'ownedPort' is read-only
https://www.eclipse.org/forums/index.php/mv/msg/452394/1006502/#msg_1006502
Juno introduced UML 2.4.1 support, so you have probably changed UML
versions.
You should use ownedAttribute instead of ownedPort.
Ed Willink
On 31/01/2013 14:01, Matteo M. wrote:
> this issue?
> Matteo]]>Ed Willink2013-01-31T14:17:33-00:00Re: Property 'ownedPort' is read-only
https://www.eclipse.org/forums/index.php/mv/msg/452394/1006518/#msg_1006518
