Eclipse Community ForumsRemote Shell Commands Not Executing
https://www.eclipse.org/forums/index.php/mv/msg/441567/990904/#msg_990904
I can open a Remote Shell to both local and remote targets.
However, I cannot execute commands. I can type the command,
but when I press [Enter], the focus shifts to output window
and nothing happens.
My installation is Eclipse Juno SR1 (build ID 20121004-1855)
running on Windows 7 with the following additional packages:
Eclipse IDE for Java Developers
1.5.1.20121004-1506
epp.package.java
Remote System Explorer End-User Runtime
3.4.1.201209191030-7L7IFBY83omx__z0RFpKdWB-r5MS
org.eclipse.rse.feature.group
Eclipse TM Project
Remote System Explorer User Actions
1.1.400.201209191030-31FBV773573L5L5393
org.eclipse.rse.useractions.feature.group
Eclipse TM Project
Any idea what I'm doing wrong? Any way I can debug what the
problem is?
-Pete]]>Peter McCann2012-12-14T18:57:45-00:00Re: Remote Shell Commands Not Executing
https://www.eclipse.org/forums/index.php/mv/msg/441567/991058/#msg_991058
- If using SSH, please try the Terminals subsystem rather than remote shell.]]>Martin Oberhuber2012-12-17T08:53:46-00:00Re: Remote Shell Commands Not Executing
https://www.eclipse.org/forums/index.php/mv/msg/441567/991144/#msg_991144
Dstore connection to a remote machine. I have not used
the SSH connection type yet.
-Pete
]]>Peter McCann2012-12-17T13:51:31-00:00Re: Remote Shell Commands Not Executing
https://www.eclipse.org/forums/index.php/mv/msg/441567/991175/#msg_991175
It used to be that up key events would contain the "enter" key but now it
seems to have changed to the down key events.
"Peter McCann" <forums-noreply@xxxxxxxx> wrote in message
news:kan813$rsg$1@xxxxxxxxe.org...
> The problem happens when I am using a Local Shell or a
> -Pete
>]]>David McKnight2012-12-17T15:34:17-00:00
