Eclipse Community ForumsObject reference for Java 1.5 or above
https://www.eclipse.org/forums/index.php/mv/msg/43134/140217/#msg_140217
schedule for that? Thanks.]]>Matthew2009-02-11T04:00:23-00:00Re: Object reference for Java 1.5 or above
https://www.eclipse.org/forums/index.php/mv/msg/43134/140267/#msg_140267
Object Reference View is replaced with Object Allocation view in Java 1.5
and above. Please use the new view for object reference information.
Eugene
"Matthew " <mhcheung@gmail.com> wrote in message
news:b8d36c4e67c8e6ea2c7aba03caa4544b$1@www.eclipse.org...
> Does Object reference table view support for Java 1.5 or above? If no, any
>]]>Eugene Chan2009-02-11T18:34:45-00:00Re: Object reference for Java 1.5 or above
https://www.eclipse.org/forums/index.php/mv/msg/43134/140279/#msg_140279
are referencing if an instance allocates comparatively large in size in
memory. How can I trace it?]]>Matthew2009-02-12T01:06:53-00:00Re: Object reference for Java 1.5 or above
https://www.eclipse.org/forums/index.php/mv/msg/43134/140320/#msg_140320
The allocation information is available when you enable the 'Track object
allocation sites' option in the profile configuration (available under 'Edit
Option' of 'Memory Analaysis'. Double click on a class in the 'Memory
Statistics' tab of the 'Object Allocations' view will auto switch to the
'Allocation Details' tab with allocation information of the selected class.
Eugene
news:503633e408e8194ef575abb48786e69e$1@www.eclipse.org...
> Thanks. But in object allocations view, I cannot get the information what
>]]>Eugene Chan2009-02-12T15:51:37-00:00Re: Object reference for Java 1.5 or above
https://www.eclipse.org/forums/index.php/mv/msg/43134/140364/#msg_140364
check which class (line number) has modified the instance to increase the
size allocated?]]>Matthew2009-02-13T01:19:57-00:00Re: Object reference for Java 1.5 or above
https://www.eclipse.org/forums/index.php/mv/msg/43134/140381/#msg_140381
Matthew2009-02-17T09:45:27-00:00Re: Object reference for Java 1.5 or above
https://www.eclipse.org/forums/index.php/mv/msg/43134/140467/#msg_140467
Only allocation information is available in the support of JVM 1.5 or above
profiling. There is no information on where the object is modified.
Eugene
news:4ba772d3b3f548d1b4cde3a9044669e5$1@www.eclipse.org...
> any update?
>]]>Eugene Chan2009-02-18T22:55:55-00:00Re: Object reference for Java 1.5 or above
https://www.eclipse.org/forums/index.php/mv/msg/43134/140488/#msg_140488
capture such information on JVM 1.5 or above?]]>Matthew2009-02-19T00:51:16-00:00Re: Object reference for Java 1.5 or above
https://www.eclipse.org/forums/index.php/mv/msg/43134/140699/#msg_140699
Matthew2009-02-24T01:16:33-00:00Re: Object reference for Java 1.5 or above
https://www.eclipse.org/forums/index.php/mv/msg/43134/140710/#msg_140710
Such feature is not yet in any future TPTP plan; However, please feel free
to submit a feature request on Eclipse Bugzilla system to TPTP for furture
release consideration.
Eugene
news:cff1c0b2c433bf5cf6a4aeb731910cc8$1@www.eclipse.org...
> Any update? Thanks!
>]]>Eugene Chan2009-02-24T04:21:40-00:00
