Eclipse Community ForumsRemove Column Property Sheet View
https://www.eclipse.org/forums/index.php/mv/msg/419776/963117/#msg_963117
Normally there are three columns in property sheet view first is property, second is value and third column does not have any header but still it is always visible.
Can we get rid of third empty column?
Cheers,]]>ModelGeek Mising name2012-10-29T15:36:07-00:00Re: Remove Column Property Sheet View
https://www.eclipse.org/forums/index.php/mv/msg/419776/967584/#msg_967584
Concerning extra columns you should have a look at this: http://blog.eclipse-tips.com/2008/05/single-column-tableviewer-and.html
I can either see the third column in the PropertySheetPage, but actually it is not visible, unless I drag it to the front.
If you want to modify the look of the PropertySheet, you´ll have to implement your own org.eclipse.ui.views.properties.IPropertySheetPage and define an Adapter for the IPropertySheetPage.
As you can see in the org.eclipse.ui.views.properties.PropertySheet.doCreatePage(IWorkbenchPart part) method the PropertySheet looks for an Adapter to show a custom IPropertySheetPage.
If you need more information do not hesitate to ask me
