Eclipse Community ForumsCannot execute Junit Plug-in tests anymore
https://www.eclipse.org/forums/index.php/mv/msg/389576/929047/#msg_929047
suddenly I cannot seem to execute Junit Plug-in tests with Buckminster
and Jenkins anymore... the jobs that used to work now fail executing
such tests... in the log I see these exceptions (see below)
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2012-09-30 03:47:32.703
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.equinox.internal.simpleconfigurator.Activator.start() of
bundle org.eclipse.equinox.simpleconfigurator.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1177)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.lang.IllegalStateException: The System Bundle was
updated. The framework must be restarted to finalize the configuration
change
at
org.eclipse.equinox.internal.simpleconfigurator.ConfigApplier.install(ConfigApplier.java:71)
at
org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:129)
at
org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:143)
at
org.eclipse.equinox.internal.simpleconfigurator.Activator.start(Activator.java:48)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 12 more
Root exception:
java.lang.IllegalStateException: The System Bundle was updated. The
framework must be restarted to finalize the configuration change
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 4 0 2012-09-30 03:47:32.710
!MESSAGE Bundle
org.eclipse.equinox.simpleconfigurator_1.0.300.v20110815-1744 [1] is not
active.
!ENTRY org.eclipse.osgi 4 0 2012-09-30 03:47:32.722
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
I don't know whether that's related... I don't have an .eclipse folder
in jenkins...
apparently the problem went away by turning those Junit Plug-in Launch
configurations to be based on features... but I really don't understand
what changed that made this problem show up: nothing had changed in my
code nor in the job configurations...
