Eclipse Community ForumsLarge logs and Eclipse Ganymede
https://www.eclipse.org/forums/index.php/mv/msg/38668/125656/#msg_125656
On Europa one configured this through the "Large Resource Support"
preferences page, but this seems to be missing on Ganymede. I have installed
everything I can think of that might be relevant from the Ganymede update
site..
- Anthony]]>Anthony Berent2008-03-06T18:22:42-00:00Re: Large logs and Eclipse Ganymede
https://www.eclipse.org/forums/index.php/mv/msg/38668/127654/#msg_127654
In principle in order to get the Large log support function working you need
to install the TPTP Log and Trace Analyzer feature.
If the update doesn't work what you can do is find out which milestone you
are using to update nd go to the TPTP 4.5 download page http://www.eclipse.org/tptp/home/downloads/?ver=4.5.0 , select the
milestoine driver that you need and download the TPTP Log and Trace Analyzer
package and unzip it on top of your Ganymede driver.
Let me know how it goes.
"Anthony Berent" <anthony.berent@arm.com> wrote in message
news:fqpcpj$5h2$1@build.eclipse.org...
> Does anybody know how to set up large log support on Ganymede (Eclipse
> 3.4)? On Europa one configured this through the "Large Resource Support"
> installed everything I can think of that might be relevant from the
> Ganymede update site..
> - Anthony
>]]>Alex Nan2008-03-31T20:53:15-00:00Re: Large logs and Eclipse Ganymede
https://www.eclipse.org/forums/index.php/mv/msg/38668/127869/#msg_127869
the all-in-one package; but unpacking the zip file solved the problem. There
is possibly an install problem here, but nothing worse.
"Alex Nan" <apnan@ca.ibm.com> wrote in message
news:fsrivt$ko2$1@build.eclipse.org...
> Which Ganymede milestone are you using?
> need to install the TPTP Log and Trace Analyzer feature.
> Analyzer package and unzip it on top of your Ganymede driver.
>> - Anthony
>]]>Anthony Berent2008-04-03T11:28:21-00:00
