Eclipse Community ForumsJet directive not found
https://www.eclipse.org/forums/index.php/mv/msg/3825/11379/#msg_11379
Originally posted by: evaandoli.dodo.com.au
Not sure what I changed but Im suddenly getting:-
Errors during build.
Errors running builder 'JET Builder' on project 'BusinessRuleJet'.
The 'jet' directive is missing in '1-1-createAttributes.jet' at line 26
column 12
column 12
The changes I can think of are I created a new project and did the JET
transform project option.
The file mentioned above has not changed at all and if I delete it just says
the next one has the same issue.
Is there a problem in the fact it says the file twice ?
Any help would be great,
Stu]]>2007-04-12T04:04:29-00:00Re: Jet directive not found
https://www.eclipse.org/forums/index.php/mv/msg/3825/11705/#msg_11705
Sounds like you may have the EMF JET builder active on you project (it goes
by the name JET Builder - the "JET2" builder calls itself "JET Template
Builder").
Open the .project file in the root of BusinessRuleJet, and look for:
If you see these lines, remove the corresponding <buildCommand> and <nature>
elements.
Paul
"Stu" <evaandoli@dodo.com.au> wrote in message
news:evkb4m$mte$1@build.eclipse.org...
> column 12
> column 12
> says the next one has the same issue.
> Stu
>]]>Paul Elder2007-04-13T12:31:49-00:00Re: Jet directive not found
https://www.eclipse.org/forums/index.php/mv/msg/3825/11740/#msg_11740
Thanks mate,
So if I have a GMF project and I want it also to be a JET Project how do I
do that ?
I used the Transform Project to Jet Eclipse Other option which I think
caused this issue.
"Paul Elder" <pelder@ca.ibm.com> wrote in message
news:evnt82$2fd$1@build.eclipse.org...
> Stu:
> goes by the name JET Builder - the "JET2" builder calls itself "JET
> Template Builder").
> <buildSpec>
> <buildCommand>
> <name>org.eclipse.emf.codegen.JETBuilder</name>
> <arguments>
> </arguments>
> </buildCommand>
> </buildSpec>
> <natures>
> <nature>org.eclipse.emf.codegen.jet.IJETNature</nature>
> </natures>
> <nature> elements.
> Paul
>> Hi,
>> column 12
>> column 12
>> Stu
>]]>2007-04-13T12:54:44-00:00Re: Jet directive not found
https://www.eclipse.org/forums/index.php/mv/msg/3825/12943/#msg_12943
Short answer:
JET projects were designed to be separate plug-ins. Life will be simpler if
the JET project is separate from the GMF one.
Some of the design logic:
A lot of the motivation of a template-based code generator is that you can
allow users to provide their own implementations of some of the templates.
In JET, this is done by creating a JET project that 'overrides' another. The
consumer of the original JET project can then be redirected to use the
overriding one. While not entirely compelling, this does argue that the code
generator should be a separate module (aka plug-ing) in the system.
Doing it anyway:
There isn't a EMFT JET wizard to install the builder and nature into an
existing plug-in project. You'll have to do it manually. The best approach
is to create a JET project, and then copy the values out of that project's
..project file into you hybred project. You want two things:
news:evnuir$5gd$1@build.eclipse.org...
> Thanks mate,
> do that ?
> caused this issue.
>> Stu:
>> Template Builder").
>> <buildSpec>
>> <buildCommand>
>> <arguments>
>> </arguments>
>> </buildCommand>
>> </buildSpec>
>> <natures>
>> </natures>
>> <nature> elements.
>> Paul
>>> Hi,
>>> column 12
>>> column 12
>>> Stu
>]]>Paul Elder2007-04-18T13:09:25-00:00
