Eclipse Community ForumsProblem in testing remote machine using agent controller
https://www.eclipse.org/forums/index.php/mv/msg/37832/123051/#msg_123051
Originally posted by: swati_gkd.rediffmail.com
(Eclipse 3.3.0, TPTP 4.4, Agent Controller 4.4)
I could launch the eclipse from windows to Linux for TPTP automation
using Agent controller.
I am facing another problem.
Consider the scenario: Start the Agent Controller on Linux-64bit
(remote) machine
1: Launch the eclipse using ant script (tptp:execution task) to
remote machine using deployment file for Linux.
The eclipse gets launched and starts replaying recorded tests. I have
a set of recorded tests in another perspective (not default java). When
eclipse starts executing tests in the respective perspective eclipse
crashes.... .
2: When I try to execute tests for the second time without stopping
agent controller, Test continues by launching eclipse perspective and
passes. This is very strange behavior. For both the cases a new workspace
is used.
3: After successful testing, If I try to test once again then even
the eclipse launch fails.
I have tried this for many times. Same cash takes place for the first
time from the agent controller started. This is very strange behavior.
When I try to execute the test case from eclipse in standard mode
using the respective deployment (for Linux) same crash takes place and a
core dumps to the bin directory of agent controller.
What can be the problem. Is it with agent controller problem? Is it a
known issue?
Please let me know the solution to resolve this problem.
Thanks and Regards,
Swati]]>2008-02-12T05:56:56-00:00Re: Problem in testing remote machine using agent controller
https://www.eclipse.org/forums/index.php/mv/msg/37832/123482/#msg_123482
Swati wrote:
> Hello,
> (remote) machine
> crashes.... .
> is used.
> known issue?
> Thanks and Regards,
> Swati
The generated crash log ( hs_err_pid*.log )file has following contents
(snippet of file) :-
Please help me to solve this problem. Thanks in advanced.
-Swati]]>2008-02-20T07:21:50-00:00Re: Problem in testing remote machine using agent controller
https://www.eclipse.org/forums/index.php/mv/msg/37832/124088/#msg_124088
This appears to be a defect in the test execution on the remote machine.
Can you reproduce the same behavor when using the local workbench UI to
launch the AGR tests on the remote machine? If so, this would be an AGR
defect and
in TPTP 4.5, the AGR was moved from a Technology Preview component to an
As-Is component. As-Is components are primarily provided for prior users
but imply no support (for example, defects, news group, and mailing lists).
If not, please open a defect against the ASF runtime with the details in
this post.
Paul
"Swati" <swati_gkd@rediffmail.com> wrote in message
news:4c92eda7c11979f668c875b266287381$1@www.eclipse.org...
> Swati wrote:
>> Hello,
>> I am facing another problem. Consider the scenario: Start the Agent
>> Controller on Linux-64bit (remote) machine
>> crashes.... .
>> is used.
>> first time from the agent controller started. This is very strange
>> behavior.
>> known issue?
>> Thanks and Regards,
>> Swati
> j
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/la ng/Object;)Ljava/lang/Object;+149
> j
> org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/l ang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
> v ~StubRoutines::call_stub
> j
> sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/refl ect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/ Object;+0
> j
> sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Objec t;[Ljava/lang/Object;)Ljava/lang/Object;+87
> j
> sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/O bject;[Ljava/lang/Object;)Ljava/lang/Object;+6
> j
> java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lan g/Object;)Ljava/lang/Object;+111
> j
> org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lan g/String;[Ljava/net/URL;)V+210
> j org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/Strin g;)V+114
> j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+ 4
> j org.eclipse.equinox.launcher.Main.main([Ljava/lang/String;)V +10
> j org.eclipse.core.launcher.Main.main([Ljava/lang/String;)V+1
> -Swati
>]]>Paul Slauenwhite2008-02-25T12:42:57-00:00Re: Problem in testing remote machine using agent controller
https://www.eclipse.org/forums/index.php/mv/msg/37832/124376/#msg_124376
even I have noticed that, running the Standalone Agent controller and
testsuite local to Linux 64bit machine. behavior is somewhat same as what
Swati has mentioned.
1st time running as local_deployment eclipse gets crashed while running
1st test case.
2nd time whole testsuite is running up to the end.
3rd time It may not launch eclipse.
bit Strange Inconsistence activities happen here
does anyone have come across these???
pls let us know to resolve this.
Chandresh Gandhi.]]>Chandresh Gandhi2008-02-26T12:13:49-00:00Re: Problem in testing remote machine using agent controller
https://www.eclipse.org/forums/index.php/mv/msg/37832/124413/#msg_124413
bit or 64 bit mode?
If this is an AGR test suite, in TPTP 4.5, the AGR was moved from a
this post.
Paul
"Chandresh Gandhi" <gandhi.chandresh@gmail.com> wrote in message
news:a89c7fdd653901dbefad0167ddafcae9$1@www.eclipse.org...
> 1st time running as local_deployment ]]>Paul Slauenwhite2008-02-26T13:50:03-00:00Re: Problem in testing remote machine using agent controller
https://www.eclipse.org/forums/index.php/mv/msg/37832/124505/#msg_124505
It's 64bit Linux test machine.
Chandresh Gandhi(Skype Id : gandhichandresh)]]>Chandresh Gandhi2008-02-27T03:13:59-00:00Re: Problem in testing remote machine using agent controller
https://www.eclipse.org/forums/index.php/mv/msg/37832/124551/#msg_124551
an AGR test?
PS
news:ea6f026d406609791195cb24f9bf320e$1@www.eclipse.org...
> Hi Paul,
>]]>Paul Slauenwhite2008-02-27T11:13:25-00:00Re: Problem in testing remote machine using agent controller
https://www.eclipse.org/forums/index.php/mv/msg/37832/124597/#msg_124597
Ofcourse It's 64 bit Agent conroller for Linux, If I'm right :)
specifically It's name is " linux_em64t " after unzip.
Is this right now pls ?
Yeah, there is a Test suite having some (12-15) AGR test cases.
Chandresh Gandhi (Skype Id : gandhichandresh)]]>Chandresh Gandhi2008-02-27T11:49:39-00:00Re: Problem in testing remote machine using agent controller
https://www.eclipse.org/forums/index.php/mv/msg/37832/124620/#msg_124620
Can you run another type of test, for example TPTP JUnit without seeing the
symptoms?
PS
news:3746c9247c3eff506557a3e27dd3fc57$1@www.eclipse.org...
> Hi Paul,
>]]>Paul Slauenwhite2008-02-27T12:44:18-00:00
