Eclipse Community ForumsCant bring BIRT reports to work with TPTP profiler.
https://www.eclipse.org/forums/index.php/mv/msg/37301/121212/#msg_121212
Originally posted by: ck2329.mail.ru
Good day
I installed all mentioned features to bring BIRT reports to work with TPTP
profiler - but im not able to create any TPTP report described in http://www.eclipse.org/tptp/home/documents/process/developme nt/Guide-to-TPTP-BIRT-Reports.html
When i do right click on host with profiling agent -> New report - > i
have only "CVS trace report", "HTML trace report", "XML trace statistics
report"
List of installed features on Eclipse version: 3.3.1.1, OS - Win XP :
with some magic - now i have "HTML report(BIRT)" in report menu - but when
i try to generate report im getting null pointer exception:
!ENTRY org.eclipse.tptp.platform.common 1 0 2008-01-23 17:49:20.771
!MESSAGE java.lang.NullPointerException
!STACK 0
at
org.eclipse.hyades.trace.ui.internal.reports.XMLTraceReportW izard.generateClassStatistics(XMLTraceReportWizard.java:135)
at
org.eclipse.hyades.trace.ui.internal.reports.XMLTraceReportW izard.generateStatistics(XMLTraceReportWizard.java:111)
at
org.eclipse.hyades.trace.ui.internal.reports.XMLTraceReportW izard.generateAgentStatistics(XMLTraceReportWizard.java:54)
at
org.eclipse.tptp.trace.report.birt.ui.internal.BIRTTraceRepo rtWizard.export(BIRTTraceReportWizard.java:90)
at
org.eclipse.tptp.trace.report.birt.ui.internal.BIRTTraceRepo rtWizard.getDomInputStream(BIRTTraceReportWizard.java:74)
at
org.eclipse.tptp.trace.report.birt.ui.internal.BIRTTraceRepo rtWizard.generate(BIRTTraceReportWizard.java:193)
at
org.eclipse.hyades.ui.internal.wizard.HyadesReportWizard$Fin ishOperation.execute(HyadesReportWizard.java:187)
at
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
at
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 934)
at
org.eclipse.hyades.ui.internal.wizard.HyadesReportWizard.per formFinish(HyadesReportWizard.java:141)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:746)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at
org.eclipse.hyades.trace.ui.internal.actions.OpenTraceReport Action.run(OpenTraceReportAction.java:61)
at
org.eclipse.tptp.trace.ui.provisional.control.provider.Abstr actControlProvider$ControlItemAdapter.run(AbstractControlPro vider.java:182)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Any hints?]]>2008-01-23T08:56:19-00:00Re: Cant bring BIRT reports to work with TPTP profiler.
https://www.eclipse.org/forums/index.php/mv/msg/37301/121253/#msg_121253
You probably need to restart Eclipse with the -clean option.
Paul
"Andrew V. Novoselsky" <ck2329@mail.ru> wrote in message
news:6f7e08b6b83b2f14def6b4d40992de6f$1@www.eclipse.org...
> Good day
> report"
> com.lowagie.itext_1.5.2.v20070608-041-w31181821
> org.apache.batik.pdf_1.6.0.v20060613-1220-0842282835-3442
> org.apache.batik_1.6.0.v20060613-1220-0842282835-3442
> org.apache.commons.codec_1.3.0.v20070907-02--w311817222849
> org.apache.derby.core_10.1.2.1
> org.eclipse.birt.chart.cshelp_2.2.1.r22x_v20070913-11--w3118 1736
> org.eclipse.birt.chart.doc.isv_2.2.1.v20070709-11--w31181736
> org.eclipse.birt.chart.runtime_2.2.1.v20070718-7Y8l77MVg3v_6 uC7shL5o
> org.eclipse.birt.chart_2.2.1.v20070709-797942epMxsxifpV0fIHD 8tiM6p
> org.eclipse.birt.crosstab_2.2.1.v20070709-3310j775Nr733G3J77
> org.eclipse.birt.cshelp_2.2.1.r22x_v20070913-11--w31181733
> org.eclipse.birt.doc.isv_2.2.1.v20070709-110-s332Aw31181_24
> org.eclipse.birt.doc_2.2.1.v20070709-110-s332Aw31181_2_
> org.eclipse.birt.example_2.2.1.v20070709-7C7C555QQ8JZTFDqAz0 Hj
> org.eclipse.birt.report.designer_2.2.1.v20070709-7U7U7EB8R4y 3DDSVyYpv9FacpRAm
> org.eclipse.birt.report.runtime_2.2.1.v20070718-7U7U7EBz0-4X -6EZboQ_la
> org.eclipse.birt_2.2.1.v20070709-7M7M7A3OP2Mz-yAItil64r9z0tw 0
> org.eclipse.cvs.source_1.0.1.R33x_r20070802-7C79_9_KKG-mDM9e 3H5D
> org.eclipse.cvs_1.0.1.R33x_r20070802-7C79_9_KKG-mDM9e3H5D
> org.eclipse.datatools.connectivity.feature_1.5.1.200709261
> org.eclipse.datatools.connectivity.oda.designer.feature_1.5. 1.200709261
> org.eclipse.datatools.connectivity.oda.feature_1.5.1.2007092 61
> org.eclipse.datatools.doc.user_1.5.1.200710161
> org.eclipse.datatools.enablement.apache.derby.feature_1.5.1. 200709261
> org.eclipse.datatools.enablement.feature_1.5.1.200709261
> org.eclipse.datatools.enablement.hsqldb.feature_1.5.1.200709 261
> org.eclipse.datatools.enablement.ibm.feature_1.5.1.200709261
> org.eclipse.datatools.enablement.jdbc.feature_1.5.1.20070926 1
> org.eclipse.datatools.enablement.jdt.feature_1.5.1.200709261
> org.eclipse.datatools.enablement.msft.feature_1.5.1.20070926 1
> org.eclipse.datatools.enablement.mysql.feature_1.5.1.2007092 61
> org.eclipse.datatools.enablement.oda.designer.feature_1.5.1. 200709261
> org.eclipse.datatools.enablement.oda.feature_1.5.1.200709261
> org.eclipse.datatools.enablement.oracle.feature_1.5.1.200709 261
> org.eclipse.datatools.enablement.postgresql.feature_1.5.1.20 0709261
> org.eclipse.datatools.enablement.sybase.feature_1.5.1.200709 261
> org.eclipse.datatools.intro_1.5.1.200709261
> org.eclipse.datatools.modelbase.feature_1.5.1.200709261
> org.eclipse.datatools.sqldevtools.data.feature_1.5.1.2007092 61
> org.eclipse.datatools.sqldevtools.ddl.feature_1.5.1.20070926 1
> org.eclipse.datatools.sqldevtools.feature_1.5.1.200709261
> org.eclipse.datatools.sqldevtools.parsers.feature_1.5.1.2007 09261
> org.eclipse.datatools.sqldevtools.results.feature_1.5.1.2007 09261
> org.eclipse.emf.codegen.ecore.ui_2.3.0.v200709252135
> org.eclipse.emf.codegen.ecore_2.3.1.v200709252135
> org.eclipse.emf.codegen.ui_2.3.0.v200709252135
> org.eclipse.emf.codegen_2.3.1.v200709252135
> org.eclipse.emf.common.ui_2.3.1.v200709252135
> org.eclipse.emf.common_2.3.0.v200709252135
> org.eclipse.emf.converter_2.3.1.v200709252135
> org.eclipse.emf.doc_2.3.1.v200709252135
> org.eclipse.emf.ecore.editor_2.3.1.v200709252135
> org.eclipse.emf.ecore.edit_2.3.0.v200709252135
> org.eclipse.emf.ecore.sdo.doc_2.3.1.v200709252135
> org.eclipse.emf.ecore.sdo.editor_2.3.0.v200709252135
> org.eclipse.emf.ecore.sdo.edit_2.3.0.v200709252135
> org.eclipse.emf.ecore.sdo.sdk_2.3.0.v200709252135
> org.eclipse.emf.ecore.sdo.source_2.3.0.v200709252135
> org.eclipse.emf.ecore.sdo_2.3.0.v200709252135
> org.eclipse.emf.ecore_2.3.1.v200709252135
> org.eclipse.emf.edit.ui_2.3.1.v200709252135
> org.eclipse.emf.edit_2.3.1.v200709252135
> org.eclipse.emf.mapping.ecore.editor_2.3.0.v200709252135
> org.eclipse.emf.mapping.ecore_2.3.0.v200709252135
> org.eclipse.emf.mapping.ui_2.3.0.v200709252135
> org.eclipse.emf.mapping_2.3.0.v200709252135
> org.eclipse.emf.sdk_2.3.1.v200709252135
> org.eclipse.emf.source_2.3.1.v200709252135
> org.eclipse.emf_2.3.1.v200709252135
> org.eclipse.gef_3.3.1.v20070814
> org.eclipse.jdt.source_3.3.1.r331_v20070629-7o7jE72EDlXAbqAc nbmyg1rf8RIL
> org.eclipse.jdt_3.3.1.r331_v20070629-7o7jE72EDlXAbqAcnbmyg1r f8RIL
> org.eclipse.jpt.feature_1.0.1.v200709130000-77-5CYQCCz-D7LQC CCD
> org.eclipse.jpt_1.0.1.v200709140000-2-184B28MbcGK02G_MRDDDE
> org.eclipse.jst.common_core.feature_2.0.0.v200706041905-1007 w311817231426
> org.eclipse.jst.enterprise_core.feature_2.0.1.v200709130705- 42Aq_kE77Y7gBHDE77
> org.eclipse.jst.enterprise_ui.feature_2.0.1.v200709130705-7b 7_ErsEU6AXKM4z-H2OSyjeRYcY
> org.eclipse.jst.enterprise_userdoc.feature_2.0.0.v2007060419 05-5-ELQAgI99h9ZJAGSOP
> org.eclipse.jst.server_adapters.feature_2.0.1.v200709110550- 787KE8gDUUEF6F_KxpHEQ
> org.eclipse.jst.server_core.feature_2.0.1.v200709110550-56CQ 9rC7EK_UAblGAD2537
> org.eclipse.jst.server_ui.feature_2.0.1.v200709110550-77-CR9 yJXEkuiKVeQrclqTHQ3648
> org.eclipse.jst.server_userdoc.feature_2.0.1.v200709110550-1 -Ah7w311819272_4_
> org.eclipse.jst.webpageeditor.feature_1.0.1.v200709110605-3- 29oA55P5V8A
> org.eclipse.jst.web_core.feature_2.0.200.v200709122200-7Q7AE 7BEHhHegvh89ftNyC
> org.eclipse.jst.web_ui.feature_2.0.1.v200709110605-7B1COCkuN a_RHevwkwAwi9_guOz-
> org.eclipse.jst.web_userdoc.feature_2.0.1.v200709110605-1-07 w31181_23
> org.eclipse.jst_2.0.1.v200709110510-7B-68dDTNImaz0di_Tvks1Jy DPVe
> org.eclipse.pde.source_3.3.2.R33x_r20071022-7N7M4CYWLBCz-yHk MIuHN
> org.eclipse.pde_3.3.2.R33x_r20071022-7N7M4CYWLBCz-yHkMIuHN
> org.eclipse.platform.source_3.3.2.R33x_v20071022-_19UEksF-G8 Yc6bUv3Dz
> org.eclipse.platform_3.3.2.R33x_v20071022-_19UEksF-G8Yc6bUv3 Dz
> org.eclipse.rcp.source_3.3.2.R33x_r20071022-8y8eE9CEV3FspP8H JrY1M2dS
> org.eclipse.rcp_3.3.2.R33x_r20071022-8y8eE9CEV3FspP8HJrY1M2d S
> org.eclipse.sdk_3.3.2.R33x_r20071022-7M7J7C_Mu2gop0b_GAwplOB hyuKO
> org.eclipse.tptp.birt_4.4.1.v200706132116-7I7G_B-hthrMpLSZUY ptCTz-cV-E
> org.eclipse.tptp.monitoring.doc.user_4.3.101.v200709261752-7 74Ai0r733G3K7E5GC7
> org.eclipse.tptp.monitoring.examples_4.3.101.v200709261752-3 28Z-w31181_372863
> org.eclipse.tptp.monitoring.instrumentation_4.3.1.v200709261 752-7A7921mA55P5VAM8PJA
> org.eclipse.tptp.monitoring.la.core_4.4.1.v200707080100-7A78 _91mA55P5S7N7_CE
> org.eclipse.tptp.monitoring.managedagent.agents_4.4.1.v20070 9261752-330-w31181_372863
> org.eclipse.tptp.monitoring.managedagent_4.4.1.v200709261752 -7E7D8c2hE77Y7gEUAYQE
> org.eclipse.tptp.monitoring.mx4j.jmx_4.4.1.v200709261752-2-2 -w31181_372863
> org.eclipse.tptp.monitoring.report.birt_4.4.1.v200707080100- 7A798b1mA55P5V_P8KID
> org.eclipse.tptp.monitoring.runtime_4.4.1.v200706132116-7U7R _E-wavnIGH7KFhrm5z08Zs8T
> org.eclipse.tptp.monitoring_4.4.1.v200707080100-7c7KEFJ7IYGH EHWXBQ5xe
> org.eclipse.tptp.platform.analysis.codereview.java_4.4.100.v 200709191245-777710r733G3K5K57AC
> org.eclipse.tptp.platform.analysis.engine_4.3.101.v200709261 752-773CG0r733G3K7E5GC7
> org.eclipse.tptp.platform.analysis_4.4.1.v200709191245-7E7_C I2hE77Y7gCaAOOK
> org.eclipse.tptp.platform.batik.pdf_4.4.0.v200706130100-05-- w31181722243_
> org.eclipse.tptp.platform.batik_4.4.0.v200703250100-7E8G-Cmz 0UWCVz-kkmD-T
> org.eclipse.tptp.platform.commons.logging_4.4.0.v20070613211 6-0-3-w311817222835
> org.eclipse.tptp.platform.core.doc.user_4.3.101.v20070926175 2-7A6CH1mA55P5VAM8PJA
> org.eclipse.tptp.platform.core_4.4.1.v200707090100-8Q82ENLJE PilAlvO15vQb
> org.eclipse.tptp.platform.doc.user_4.3.101.v200709261752-7A7 7CH08IIrT11IGIcOfKRIYPB
> org.eclipse.tptp.platform.examples_4.3.101.v200709261752-328 Z-w31181_372863
> org.eclipse.tptp.platform.instrumentation.ui_4.2.1.v20070926 1752-320-w31181_372863
> org.eclipse.tptp.platform.integration.pde_4.4.1.v20070926175 2-330-w31181_372863
> org.eclipse.tptp.platform.jakarta.log4j_4.4.0.v200706132116- 017B-w311817222529
> org.eclipse.tptp.platform.jvmti_4.3.1.v200709261752-777710r7 33G3K7E5GC7
> org.eclipse.tptp.platform.la.core_4.3.101.v200707090100-328Z -w31181_2_2356
> org.eclipse.tptp.platform.lta_4.3.101.v200707090100-773Ai0r7 33G3K6H5BB_
> org.eclipse.tptp.platform.probekit.doc.user_4.3.101.v2007092 61752-318Z-w31181_372863
> org.eclipse.tptp.platform.probekit_4.3.101.v200709261752-7E5 EAY2hE77Y7gEUAYQE
> org.eclipse.tptp.platform.profile.server_4.3.1.v200709261752 -7E798c2hE77Y7gEUAYQE
> org.eclipse.tptp.platform.report.birt_4.3.101.v200709261752- 777710r733G3K7E5GC7
> org.eclipse.tptp.platform.report_4.2.101.v200709261752-7A5CH 1mA55P5VAM8PJA
> org.eclipse.tptp.platform.runtime_4.4.1.v200706132116-8I83EI X1JNK7dwt7tHntrj6xnH84
> org.eclipse.tptp.platform.samples_4.3.101.v200709261752-7A4D r1mA55P5VAM8PJA
> org.eclipse.tptp.platform.statistical.report.birt_4.4.1.v200 709261752-777710r733G3K7E5GC7
> org.eclipse.tptp.platform.statistical.ui_4.1.301.v2007092617 52-772CG0r733G3K7E5GC7
> org.eclipse.tptp.platform.trace_4.3.101.v200707090100-7E7AAk 2hE77Y7gDXATPH
> org.eclipse.tptp.platform.xerces_4.4.0.v200706132116-278-0r7 33G3C944983
> org.eclipse.tptp.test.report.birt_4.3.101.v200709261752-7A7A 21mA55P5VAM8PJA
> org.eclipse.tptp.trace.arm.ui_4.3.1.v200709261752-77510r733G 3K7E5GC7
> org.eclipse.tptp.trace.arm_4.2.1.v200709261752-77210r733G3K7 E5GC7
> org.eclipse.tptp.trace.jvmti_4.2.1.v200709261752-330-w31181_ 372863
> org.eclipse.tptp.trace.report.birt_4.4.1.v200709261752-7A7A2 1mA55P5VAM8PJA
> org.eclipse.tptp.trace.runtime_4.3.1.v200709261752-7E783-UUE NBmM3RiQ4UxVz-eZD8
> org.eclipse.tptp.trace_4.2.1.v200709261752-771E9y0r733G3K7E5 GC7
> org.eclipse.wst.common_core.feature_2.0.1.v200709110622-7C78 EKGE_EkMNfNleyerlz
> org.eclipse.wst.common_ui.feature_2.0.1.v200709110622-7C5EH2 E9RvTVnijrspVz0bgOmfz-
> org.eclipse.wst.server_adapters.feature_2.0.1.v200709110637- 4-0_kE77Y7TGAoAAJ
> org.eclipse.wst.server_core.feature_2.0.1.v200709110637-2-CM 8s733G3G5Jc
> org.eclipse.wst.server_ui.feature_2.0.1.v200709110637-77-CU9 vCXCjvdHL7ATINi447
> org.eclipse.wst.server_userdoc.feature_2.0.1.v200709110637-1 -Aj7w311816413336
> org.eclipse.wst.web_core.feature_2.0.1.v200709111200-42CK_kE 77Y7ZBNCQGG
> org.eclipse.wst.web_ui.feature_2.0.1.v200709111200-7A0EAiCiW fGJsJZlAhE3TMaQW
> org.eclipse.wst.web_userdoc.feature_2.0.1.v200709111200-20Ag 8s733G3C93777C
> org.eclipse.wst.ws_core.feature_2.0.1.v200709051445-7E7KEB0E C3wSU4Tuh9iKz
> org.eclipse.wst.ws_ui.feature_2.0.1.v200709051445-791ECFAufY O8Az-ajoKBCFe8tVjL
> org.eclipse.wst.ws_userdoc.feature_2.0.0.v200706041905-34Ds9 oA55P5L_97C9J
> org.eclipse.wst.xml_core.feature_2.0.1.v200709110650-787BE_1 CYQCCz-CvRQLQSV
> org.eclipse.wst.xml_ui.feature_2.0.1.v200709110650-7A1ECGCnb ckz0bnr5wCp8KNAjipR
> org.eclipse.wst.xml_userdoc.feature_2.0.1.v200709110650-4-EG k_kE77Y7QI7EEEQ
> org.eclipse.wst_2.0.1.v200709110510-7C-778k0JWNr93WEIHvplSVo jWel
> org.eclipse.xsd.doc_2.3.1.v200709252135
> org.eclipse.xsd.ecore.converter_2.3.1.v200709252135
> org.eclipse.xsd.editor_2.3.0.v200709252135
> org.eclipse.xsd.edit_2.3.0.v200709252135
> org.eclipse.xsd.mapping.editor_2.3.0.v200709252135
> org.eclipse.xsd.mapping_2.3.0.v200709252135
> org.eclipse.xsd.sdk_2.3.1.v200709252135
> org.eclipse.xsd.source_2.3.1.v200709252135
> org.eclipse.xsd_2.3.1.v200709252135
> org.mozilla.rhino_1.6.0.v20070406-05--w31181821
> org.w3c.sac_1.3.0.v20070406-02--w31181821
>]]>Paul Slauenwhite2008-01-23T11:40:55-00:00Re: Cant bring BIRT reports to work with TPTP profiler.
https://www.eclipse.org/forums/index.php/mv/msg/37301/121262/#msg_121262
What profiling options are you using to generate the trace that you want
to report? Looking at the code, it trace element that is being reported
cannot resolve the ID of the loading thread.
Paul
news:6bd844a276aba82907cd6a9ae270cecc$1@www.eclipse.org...
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any hints?
>]]>Paul Slauenwhite2008-01-23T11:42:03-00:00Re: Cant bring BIRT reports to work with TPTP profiler.
https://www.eclipse.org/forums/index.php/mv/msg/37301/121278/#msg_121278
I used Memory Analysis - but thread analisys has the same behaviour]]>2008-01-23T14:56:07-00:00Re: Cant bring BIRT reports to work with TPTP profiler.
https://www.eclipse.org/forums/index.php/mv/msg/37301/121318/#msg_121318
This appears to be a bug. Unfortunately, in TPTP 4.5, the BIRT reports
was moved from a General Availability (GA) component to an As-Is component.
As-Is components are primarily provided for prior users but imply no support
(for example, defects, news group, and mailing lists).
Paul
news:843ac1cac1d9c5f8bb0c1a5864f485cf$1@www.eclipse.org...
>]]>Paul Slauenwhite2008-01-24T11:27:12-00:00Re: Cant bring BIRT reports to work with TPTP profiler.
https://www.eclipse.org/forums/index.php/mv/msg/37301/121338/#msg_121338
But im using TPTP 4.4.0.03 - is there same situation with BIRT reports ?
BTW: when do you plan to release TPTP 4.5? as i understood it will come
with new Eclipse release, this summer - am i right ?]]>2008-01-24T14:58:57-00:00Re: Cant bring BIRT reports to work with TPTP profiler.
https://www.eclipse.org/forums/index.php/mv/msg/37301/121407/#msg_121407
Unfortunately, development for the next 4.4.x mainataince release
(4.4.1) has closed, so this problem would have to be fixed in 4.5 (target:
June 2008).
Paul
news:a1b63c1b422447c7095786c4777f5a8c$1@www.eclipse.org...
>]]>Paul Slauenwhite2008-01-25T17:50:19-00:00
