Eclipse Community ForumsHow can I set multiple root to treeviewer using emf adapterfactoryContentProvider
https://www.eclipse.org/forums/index.php/mv/msg/364976/889615/#msg_889615
I want to set multiple roots for my treeviewer.
My program uses AdapterFactoryContentProvider as the tree viewer content provider but I was using single root.
Now when I wanted to add multiple root I knew that I should use ArrayContentProvider
is there something like this in EMF or I should adapt all previous code to the jface ArrayContentProvider ?
Thanks]]>becks m2012-06-19T12:11:14-00:00Re: How can I set multiple root to treeviewer using emf adapterfactoryContentProvider
https://www.eclipse.org/forums/index.php/mv/msg/364976/889643/#msg_889643
that as input to the view. In the constructor you can specify the
collection of objects you want as roots displayed in the tree view.
On 19/06/2012 8:11 AM, becks m wrote:
> Hi guys,
> is there something like this in EMF I should adapt all previous code
> Thanks]]>Ed Merks2012-06-19T12:41:27-00:00Re: How can I set multiple root to treeviewer using emf adapterfactoryContentProvider
https://www.eclipse.org/forums/index.php/mv/msg/364976/889655/#msg_889655
Ed Merks wrote on Tue, 19 June 2012 08:41
You can create an org.eclipse.emf.edit.provider.ItemProvider and use
> Hi guys,
> Thanks
Thanks Ed,
I already have org.eclipse.emf.edit.provider.ItemProvider created for all my classes and that was used by adapterfactorycontentprovider.
In which constructor you mean ? can you please clarify this point .
becks]]>becks m2012-06-19T12:56:12-00:00Re: How can I set multiple root to treeviewer using emf adapterfactoryContentProvider
https://www.eclipse.org/forums/index.php/mv/msg/364976/889683/#msg_889683
your generated item providers, with ItemProvider? I'm pretty sure
ItemProvider(Collection) will provide what you need.
>> > Hi guys,
>> > My program uses AdapterFactoryContentProvider as the tree viewer >
>> > Now when I wanted to add multiple root I knew that I should use >
>> code > to the jface ArrayContentProvider ?
>> > Thanks
> Thanks Ed,
> becks]]>Ed Merks2012-06-19T13:22:30-00:00Re: How can I set multiple root to treeviewer using emf adapterfactoryContentProvider
https://www.eclipse.org/forums/index.php/mv/msg/364976/889702/#msg_889702
Now, I got your point, and I'll give it a try and get back if there is something else
