!ENTRY system.bundle 4 0 2012-05-28 12:45:34.156
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start() of bundle system.bundle.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:1010)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:966)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:549)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:484)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:275)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.launch(StartLevelManager.java:245)
at org.eclipse.osgi.framework.internal.core.SystemBundle.resume(SystemBundle.java:155)
at org.eclipse.osgi.framework.internal.core.Framework.launch(Framework.java:503)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.java:51)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:289)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:173)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.IllegalStateException
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.checkSystemState(BaseStorage.java:654)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.getStateManager(BaseStorage.java:634)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.getPlatformAdmin(BaseAdaptor.java:385)
at org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook.frameworkStart(EclipseAdaptorHook.java:80)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.frameworkStart(BaseAdaptor.java:260)
at org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start(SystemBundleActivator.java:55)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:991)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:985)
... 18 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2012-05-28 12:45:34.187
!MESSAGE Startup error
!STACK 1
java.lang.RuntimeException: Exception in org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start() of bundle system.bundle.
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:557)
!SESSION Mon May 28 12:45:34 EDT 2012 ------------------------------------------
!ENTRY org.eclipse.core.launcher 4 0 2012-05-28 12:45:34.218
!MESSAGE Exception launching the Eclipse Platform:
!STACK
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:186)
at org.eclipse.core.launcher.Main.main(Main.java:952)]]>Kyle Figueroa2012-05-28T16:48:16-00:00Re: Stanford Eclipse Log Error! Please help?
https://www.eclipse.org/forums/index.php/mv/msg/356337/878166/#msg_878166
Daniel Hickey2012-05-28T18:27:55-00:00Re: Stanford Eclipse Log Error! Please help?
https://www.eclipse.org/forums/index.php/mv/msg/356337/878170/#msg_878170
Kyle Figueroa2012-05-28T18:35:22-00:00Re: Stanford Eclipse Log Error! Please help?
https://www.eclipse.org/forums/index.php/mv/msg/356337/878241/#msg_878241
]]>Kyle Figueroa2012-05-28T22:43:05-00:00Re: Stanford Eclipse Log Error! Please help?
https://www.eclipse.org/forums/index.php/mv/msg/356337/878350/#msg_878350
Can you try a folder outside "C:\Program Files"? There has been issues
in the past with different versions of Windows. Some are related to new
security features in Windows. The latest Eclipse version should run fine
but older versions (such as Eclipse 3.2) will fail.
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx http://wagenknecht.org/]]>Gunnar Wagenknecht2012-05-29T06:00:37-00:00Re: Stanford Eclipse Log Error! Please help?
https://www.eclipse.org/forums/index.php/mv/msg/356337/878701/#msg_878701
Also, please do not use this newsgroup for programming, usage problems.
This newsgroup is solely for announcements, discussions, of the Eclipse
Foundation entity. It is not a newsgroup for technical discussions.
Rich Kulp]]>2012-05-29T19:08:22-00:00Re: Stanford Eclipse Log Error! Please help?
https://www.eclipse.org/forums/index.php/mv/msg/356337/895791/#msg_895791
Thank you in advance.
I fixed it! All you have to do is download the newest version of eclipse classic and then extract the Stanford version and the new version and take all of the stuff from the Stanford version and put them in the right places in the new eclipse folders and launch e new eclipse and it will be all Stanford! Hope I helped if you have any questions please ask
]]>David Gadea2012-07-16T04:59:54-00:00Re: Stanford Eclipse Log Error! Please help?
https://www.eclipse.org/forums/index.php/mv/msg/356337/972230/#msg_972230
I was also facing the same error..
According to comments mentioned here, I took latest plugins and features for eclipse..
And it did work
Thanks..]]>deepali k2012-11-05T13:08:41-00:00Re: Stanford Eclipse Log Error! Please help?
https://www.eclipse.org/forums/index.php/mv/msg/356337/990212/#msg_990212
Pauline Taylor2012-12-11T12:31:36-00:00Re: Stanford Eclipse Log Error! Please help?
https://www.eclipse.org/forums/index.php/mv/msg/356337/992632/#msg_992632
EDEN CHEN2012-12-22T05:54:56-00:00Re: Stanford Eclipse Log Error! Please help?
https://www.eclipse.org/forums/index.php/mv/msg/356337/1008543/#msg_1008543
Hi, this is my solution :
I had the same problem, I think the problem is that Stanford university offers an old version of eclipse that doesn't work with new version of jdk/jre, some people suggested re-installing jdk/jre but that didn't work in my case.
Solution 1 (using Stanford's eclipse):
- Uninstall the jdk/jre -if you already have it-.
- Download eclipse afforded by Stanford website.
- Download JAVA 1.6 jre afforded by Stanford website, and install it.
- Run eclipse.
Solution 2 (using new/different version of eclipse):
-At this step you have two version of Eclipse,
> extract/decompose the downloaded file -Stanford's eclipse- and find a file named "plugins", juts copy everything from it.
> go to the file where you have the new/different version of eclipse that you are using and find a file called "plugins", paste what you copied from other file to it
- Run eclipse -your version of eclipse-.
note: I did this on Eclipse IDE for Java EE Developers (Juno) and Eclipse classic 4.2.1 (Juno), both worked.
Learn and Share!]]>Bilal Korir2013-02-12T22:20:07-00:00Re: Stanford Eclipse Log Error! Please help?
https://www.eclipse.org/forums/index.php/mv/msg/356337/1008548/#msg_1008548
Hi, this is my solution:
re-install jdk/jre but that didn't work in my case.
- Run eclipse.
- Download eclipse afforded by Stanford afforded by Stanford website.
-at this at this step you have two version of Eclipse,
> extract/decompose the downloaded file -Stanford's eclipse- you will find a file named "plugins", juts copy everything from it
> go to the file where you have the new/different version of eclipse that you are using and find a file called "plugins", paste what you copied to it.
Note: applied on Eclipse IDE for Java EE Developers and Eclipse Classic 4.2.1.
Learn and Share.
]]>Bilal Korir2013-02-12T22:32:51-00:00Re: Stanford Eclipse Log Error! Please help?
https://www.eclipse.org/forums/index.php/mv/msg/356337/1028298/#msg_1028298
According to comments mentioned here, I took latest plugins and features for eclipse..]]>phan long2013-03-28T04:18:17-00:00Re: Stanford Eclipse Log Error! Please help?
https://www.eclipse.org/forums/index.php/mv/msg/356337/1044087/#msg_1044087
Put at the top of eclipse.ini file the following rows after correcting the jdk path:
