Eclipse Community Forums[GWT] Could not initialize class org.eclipse.emf.server.ecore.resource.URIServiceImpl
https://www.eclipse.org/forums/index.php/mv/msg/352206/872629/#msg_872629
I recently tried to run my EMF model as an Web application and used the GWT editor project generation for this. Unfortunately when starting the GWT Web Application the application loads but the console outputs the following stack trace:
Mai 16, 2012 3:05:19 PM com.google.apphosting.utils.jetty.JettyLogger warn
WARNING: Error for /Project.ProjectEditor/uriService
java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.emf.server.ecore.resource.URIServiceImpl
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:525)
at java.lang.Class.newInstance0(Class.java:372)
at java.lang.Class.newInstance(Class.java:325)
at org.mortbay.jetty.servlet.Holder.newInstance(Holder.java:153)
at org.mortbay.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:428)
at org.mortbay.jetty.servlet.ServletHolder.getServlet(ServletHolder.java:339)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1166)
at com.google.appengine.tools.development.HeaderVerificationFilter.doFilter(HeaderVerificationFilter.java:35)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1157)
at com.google.appengine.api.blobstore.dev.ServeBlobFilter.doFilter(ServeBlobFilter.java:60)
at com.google.apphosting.utils.servlet.TransactionCleanupFilter.doFilter(TransactionCleanupFilter.java:43)
at com.google.appengine.tools.development.StaticFileFilter.doFilter(StaticFileFilter.java:122)
at com.google.appengine.tools.development.BackendServersFilter.doFilter(BackendServersFilter.java:97)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:388)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:418)
at com.google.appengine.tools.development.DevAppEngineWebAppContext.handle(DevAppEngineWebAppContext.java:78)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at com.google.appengine.tools.development.JettyContainerService$ApiProxyHandler.handle(JettyContainerService.java:369)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:923)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:547)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Has anyone an idea how I to fix this?
Alex]]>Alex Lenk2012-05-16T13:45:59-00:00Re: [GWT] Could not initialize class org.eclipse.emf.server.ecore.resource.URIServiceImpl
https://www.eclipse.org/forums/index.php/mv/msg/352206/872743/#msg_872743
That should be on the classpath. In particular, the builder EMF adds
should have automatically copied the org.eclipse.emf.ecore jar to the
war/WEB-INF/lib folder. It does that for me...
On 16/05/2012 3:46 PM, Alex Lenk wrote:
> Hello,
> warn
> Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Alex]]>Ed Merks2012-05-16T18:25:05-00:00Re: [GWT] Could not initialize class org.eclipse.emf.server.ecore.resource.URIServiceImpl
https://www.eclipse.org/forums/index.php/mv/msg/352206/875245/#msg_875245
I try a new clean installation and see if the problem still exists. Thanks!]]>Alex Lenk2012-05-22T11:59:19-00:00Re: [GWT] Could not initialize class org.eclipse.emf.server.ecore.resource.URIServiceImpl
https://www.eclipse.org/forums/index.php/mv/msg/352206/1357082/#msg_1357082
Did starting from scratch help in your case?
I have had the same problem for while and tried clean installation also, without any luck!
Actually I am not sure if this is related to the second warning I get
WARN::Nested in java.lang.ExceptionInInitializerError:
java.lang.SecurityException: class "org.eclipse.emf.ecore.impl.EFactoryImpl"'s signer information does not match signer information of other classes in the same package
I have seen another Forum topic on the "signer" problem. However I did not understand completely how to solve that problem either.
The problem arises when I try "save" from the created website.
