Eclipse Community ForumsHow to change the value of LimitRequestFieldSize in virgo tomcat server
https://www.eclipse.org/forums/index.php/mv/msg/351208/870420/#msg_870420
How and where to change the value of LimitRequestFieldSize in virgo tomcat server.
karthik]]>karthik elavan2012-05-08T06:33:13-00:00Re: How to change the value of LimitRequestFieldSize in virgo tomcat server
https://www.eclipse.org/forums/index.php/mv/msg/351208/870438/#msg_870438
I think that this property is for Apache HTTP Server - http://httpd.apache.org/docs/2.0/mod/core.html
This directive specifies the number of bytes that will be allowed in an HTTP request header.
The maximum size of the request and response HTTP header, specified in bytes.
Violeta]]>Violeta Georgieva2012-05-08T08:38:22-00:00Re: How to change the value of LimitRequestFieldSize in virgo tomcat server
https://www.eclipse.org/forums/index.php/mv/msg/351208/870729/#msg_870729
I have opened the tomcat-server.xml file which is located in VIRGO-SERVER-HOME/config folder
and added the attribute maxHttpHeaderSize like below in all connector ports:
Is this correct?]]>karthik elavan2012-05-09T13:26:22-00:00Re: How to change the value of LimitRequestFieldSize in virgo tomcat server
https://www.eclipse.org/forums/index.php/mv/msg/351208/870739/#msg_870739
Violeta Georgieva2012-05-09T13:49:21-00:00Re: How to change the value of LimitRequestFieldSize in virgo tomcat server
https://www.eclipse.org/forums/index.php/mv/msg/351208/870923/#msg_870923
karthik elavan2012-05-10T09:22:07-00:00
