Eclipse Community Forums[QVT tutorial] How can I debug (step into) script ?
https://www.eclipse.org/forums/index.php/mv/msg/351074/869942/#msg_869942
I followed the QVT tutorial here (http://redpanda.nl/index.php?p=tutorial)
Good explanations, by the way. Good for a starter like me.
I am at the last step (Step9) where I transform the instance1 of a
metamodel A into an instance2 a metamodel B.
But, I do not get much output in the trace log file, even if everything
seems to as terminated correctly.
Is there a way to debug (step into) or force more traces in the script
file (file.qvto) ?
I tried the Eclipse Debug View but, it does not stop in the script.
Thanks in advance.]]>Alain Lavoie2012-05-05T00:20:36-00:00Re: [QVT tutorial] How can I debug (step into) script ?
https://www.eclipse.org/forums/index.php/mv/msg/351074/869944/#msg_869944
> file (file.qvto) ?
> Thanks in advance.
Ok, the deubugger seems to work now.]]>Alain Lavoie2012-05-05T00:42:41-00:00Re: [QVT tutorial] How can I debug (step into) script ?
https://www.eclipse.org/forums/index.php/mv/msg/351074/869969/#msg_869969
Please use just the QVTo newsgroup fort QVTo-specific issues.
Ed Willink
On 05/05/2012 01:20, Alain Lavoie wrote:
> file (file.qvto) ?
> Thanks in advance.]]>Ed Willink2012-05-05T10:00:19-00:00Re: [QVT tutorial] How can I debug (step into) script ?
https://www.eclipse.org/forums/index.php/mv/msg/351074/870049/#msg_870049
> Hi
> Regards
> Ed Willink
Ok, I still do not understand when web based forum is synchronize with this
newsgroup, or are they two different discussion groups ?
I am a nntp newbie and will try to follow your M2M to MMT annoncement.
I will still make mistakes, but due to my incomprehensions, forgive me
in advances.]]>Alain Lavoie2012-05-06T02:58:57-00:00
