Eclipse Community ForumsD&D in TextEditor
https://www.eclipse.org/forums/index.php/mv/msg/349946/867364/#msg_867364
I do get the following error:
!ENTRY org.eclipse.ui 4 0 2012-05-01 10:33:50.865
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.ui.internal.EditorSiteDragAndDropServiceImpl$1.dragLeave(EditorSiteDragAndDropServiceImpl.java:107)
at org.eclipse.swt.dnd.DNDListener.handleEvent(DNDListener.java:70)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
at org.eclipse.swt.dnd.DropTarget.Drop(DropTarget.java:403)
at org.eclipse.swt.dnd.DropTarget$3.method6(DropTarget.java:258)
at org.eclipse.swt.internal.ole.win32.COMObject.callback6(COMObject.java:119)
at org.eclipse.swt.internal.ole.win32.COM.DoDragDrop(Native Method)
at org.eclipse.swt.dnd.DragSource.drag(DragSource.java:363)
at org.eclipse.swt.dnd.DragSource.access$0(DragSource.java:289)
at org.eclipse.swt.dnd.DragSource$1.handleEvent(DragSource.java:172)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at it.condarelli.writer.Writer.start(Writer.java:42)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
I also traced the call to initializeDragAndDrop(getSourceViewer());, but
Platform.getAdapterManager().loadAdapter(this, "org.eclipse.ui.texteditor.ITextEditorDropTargetListener");
returns null.
It seems to install correctly installTextDragAndDrop(viewer).
but it doesn't work because in the DropTargetEvent data, dataTypes and currentDataType are all null.
Get ApprporiateListener() tries to return secondaryListener, but that is also null.
What do I miss?
TiA
Mauro]]>Mauro Condarelli2012-05-01T08:53:52-00:00Re: D&D in TextEditor
https://www.eclipse.org/forums/index.php/mv/msg/349946/868991/#msg_868991
> Is TextEditor supposed to support D&D without further customization?
> !STACK 0
Can someone suggest a "more proper" fix?
That one involves ignoring "restrictions" in the lib.
I was not able to find an associated bug; should I open one?
Mauro
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> returns null.
> What do I miss?
> TiA
> Mauro]]>Mauro Condarelli2012-05-02T20:24:59-00:00
