sqlcmd -E -S localhost\SQLEXPRESS2 (This is the name of the instance) 1> 2> select @@servername 3> go ------------------------------------------------------------------------------ AYMAN_METWALLY\SQLEXPRESS2
Apr 27, 2012 10:22:47 AM org.apache.catalina.core.AprLifecycleListener init]]>
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jre6\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files (x86)\Common Files\Acronis\SnapAPI\;C:\Program Files (x86)\Java\jre6\bin;C:\Program Files\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\Java\jre6\bin;C:\Program Files\Microsoft Network Monitor 3\;.
Apr 27, 2012 10:22:47 AM org.apache.tomcat.util.digester.SetPropertiesRule begin
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:ccms' did not find a matching property.
Apr 27, 2012 10:22:47 AM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8081
Apr 27, 2012 10:22:47 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 570 ms
Apr 27, 2012 10:22:47 AM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Apr 27, 2012 10:22:47 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.35
Apr 27, 2012 10:22:48 AM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Error configuring application listener of class com.pg.ccms.scheduler.CCMSApplicationListener
java.lang.ClassNotFoundException: com.pg.ccms.scheduler.CCMSApplicationListener
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1680)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1526)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4149)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4705)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
at org.apache.catalina.core.StandardService.start(StandardService.java:525)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
SEVERE: Skipped installing application listeners due to previous error(s)
Apr 27, 2012 10:22:48 AM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/ccms] startup failed due to previous errors
Apr 27, 2012 10:22:48 AM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8081
Apr 27, 2012 10:22:48 AM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8019
Apr 27, 2012 10:22:48 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/29 config=null
Apr 27, 2012 10:22:48 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 337 ms
jdbc:sqlserver://localhost:1433;databaseName=CCMSDB
