Eclipse Community ForumsDiagram layouts
https://www.eclipse.org/forums/index.php/mv/msg/325888/840078/#msg_840078
The other thing I've been struggling with is diagram layouts. I have a simple flow-style diagram that shouldn't be too difficult to auto-layout, but haven't seen a good way to implement it.
Is there a better way than hand-coding individual shape locations during the import process?
Joao]]>Joao S2012-04-10T08:22:01-00:00Re: Diagram layouts
https://www.eclipse.org/forums/index.php/mv/msg/325888/840789/#msg_840789
Thanks for the link. Already found that and was playing with it but didn't get far. Do you have an example where it works for nested container shapes? I have a diagram with a root container shape that contains several container shapes of its own. And I've mangled the example code to get it to do some very intriguing things with the diagram, but not exactly what I want (i.e. the diagram becomes huge and things get moved and resized quite oddly).
Layouts are definitely not my forte. ]]>Brian Fitzpatrick2012-04-10T14:14:03-00:00Re: Diagram layouts
https://www.eclipse.org/forums/index.php/mv/msg/325888/840818/#msg_840818
http://www.eclipse.org/forums/index.php/m/758628/
Which offers a way to use a Zest layout, but it doesn't seem to work for my nested diagram approach...]]>Brian Fitzpatrick2012-04-10T14:48:12-00:00Re: Diagram layouts
https://www.eclipse.org/forums/index.php/mv/msg/325888/840828/#msg_840828
Have a look at graphviz, it may provide the layouter you need.]]>Sylvain EVEILLARD2012-04-10T15:02:38-00:00Re: Diagram layouts
https://www.eclipse.org/forums/index.php/mv/msg/325888/840836/#msg_840836
Brian Fitzpatrick2012-04-10T15:11:47-00:00
