Eclipse Community ForumsCreating a SysML model
https://www.eclipse.org/forums/index.php/mv/msg/261553/754840/#msg_754840
I'm quite new using Papyrus and I'm having a hard time trying to create a SysML model. That's how far I've got: I've created an UML model and applied the SysML profile to it. Everything seems ok, but I couldn't figure out how to add SysML diagrams or elements. I could find how to create UML diagrams and elements. I also found the way to add SysML's sterotypes to elements (I haven't tried stereotyping an UML diagram). Is that the way to create a SysML model? I mean, I should create UML diagrams and elements and then stereotype them with SysML profile? If that's the way, how could I create elements specific to SysML (e.g. parametric diagram)?
Thanks a lot for the help,
Wagner]]>Wagner 2011-11-04T15:10:18-00:00Re: Creating a SysML model
https://www.eclipse.org/forums/index.php/mv/msg/261553/755194/#msg_755194
I think for you the best way to have a SysML model is create it from scratch.
To do so use the following instructions:
1. New -> other..
2. Papyrus Project
3. Give the wanted name
4. Next
5. Select SysML model
6. Next
7. Select the diagram you want to start with
8. Finish
9. From now in the "Model Explorer" view (Papyrus perspective) you should be able to add SysML Diagrams.
