Eclipse Community ForumsProblem when migrate to birt 3.7
https://www.eclipse.org/forums/index.php/mv/msg/261148/753398/#msg_753398
I am using ReportEngine in a standalone application. My application is packed with onejar and with birt 2.6 all working fine. When I was trying to generate report using 3.7.0 I got the following error:
WARING: Failed to install plugin from onejar:lib/
java.lang.ClassCastException: sun.misc.Launcher$AppClassLoader cannot be cast to com.simontuffs.onejar.JarClassLoader
This error happened at Platform.startup( config ) method.
I already removed config.setEngineHome().
Please anyone can help me?]]>Leon Tan2011-10-27T04:22:14-00:00Re: Problem when migrate to birt 3.7
https://www.eclipse.org/forums/index.php/mv/msg/261148/753532/#msg_753532
engine download/reportengine/lib to your apps classpath and remove the
setEngineHome method. Any chance you could post your app?
Jason
On 10/27/2011 12:22 AM, queenie wrote:
> Please anyone can help me?]]>Jason Weathersby2011-10-27T15:15:48-00:00
