<modelVersion>4.0.0</modelVersion>
<groupId>com.hemna.oo</groupId>
<artifactId>foo</artifactId>
<version>1.0.0-SNAPSHOT</version>
<packaging>pom</packaging>
<modules>
<module>foo-plugin</module>
</modules>
<properties>
<tycho-version>0.12.0</tycho-version>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
</properties>
<build>
<plugins>
<plugin>
<groupId>org.eclipse.tycho</groupId>
<artifactId>tycho-maven-plugin</artifactId>
<version>${tycho-version}</version>
<extensions>true</extensions>
</plugin>
<plugin>
<artifactId>target-platform-configuration</artifactId>
<configuration>
<resolver>p2</resolver>
<pomDependencies>consider</pomDependencies>
<environments>
<environment>
<os>linux</os>
<ws>gtk</ws>
<arch>x86</arch>
</environment>
<environment>
<os>linux</os>
<ws>gtk</ws>
<arch>x86_64</arch>
</environment>
<environment>
<os>win32</os>
<ws>win32</ws>
<arch>x86</arch>
</environment>
<environment>
<os>win32</os>
<ws>win32</ws>
<arch>x86_64</arch>
</environment>
<environment>
<os>macosx</os>
<ws>cocoa</ws>
<arch>x86_64</arch>
</environment>
</environments>
</configuration>
</plugin>
</plugins>
</build>
<repositories>
<repository>
<id>p2.eclipse.indigo</id>
<layout>p2</layout>
<url>URL to indigo...forum wouldn't let me leave the real url here....</url>
</repository>
</repositories>
</project>
<parent>
<artifactId>foo-plugin</artifactId>
</parent>
<groupId>com.hemna.oo.foo</groupId>
<artifactId>com.hemna.oo.foo.shared</artifactId>
<packaging>eclipse-plugin</packaging>
<dependencies>
<dependency>
<groupId>com.google.code.gson</groupId>
<artifactId>gson</artifactId>
<version>1.7.1</version>
</dependency>
</dependencies>
</project>
[INFO] Cannot complete the request. Generating details.
[INFO] {org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1, osgi.ws=gtk, osgi.arch=x86, osgi.os=linux, org.eclipse.update.install.features=true, org.osgi.framework.system.packages=}
[INFO] [Software being installed: com.hemna.oo.foo.debug.core 1.0.0.qualifier, Missing requirement: com.hemna.oo.foo.shared 1.0.0.qualifier requires 'bundle com.google.gson [1.7.0,2.0.0)' but it could not be found, Cannot satisfy dependency: com.hemna.oo.foo.debug.core 1.0.0.qualifier depends on: bundle com.hemna.oo.foo.shared [1.0.0,4.0.0)]
[ERROR] Internal error: java.lang.RuntimeException: org.eclipse.equinox.p2.core.ProvisionException: No solution found because the problem is unsatisfiable. -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: java.lang.RuntimeException: org.eclipse.equinox.p2.core.ProvisionException: No solution found because the problem is unsatisfiable.
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:168)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
Caused by: java.lang.RuntimeException: org.eclipse.equinox.p2.core.ProvisionException: No solution found because the problem is unsatisfiable.
at org.eclipse.tycho.p2.impl.resolver.ProjectorResolutionStrategy.resolve(ProjectorResolutionStrategy.java:102)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveProject(P2ResolverImpl.java:324)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveProject(P2ResolverImpl.java:293)
at org.eclipse.tycho.p2.facade.P2TargetPlatformResolver.doResolvePlatform(P2TargetPlatformResolver.java:389)
at org.eclipse.tycho.p2.facade.P2TargetPlatformResolver.resolvePlatform(P2TargetPlatformResolver.java:150)
at org.eclipse.tycho.core.resolver.DefaultTychoDependencyResolver.resolveProject(DefaultTychoDependencyResolver.java:90)
at org.eclipse.tycho.core.maven.TychoMavenLifecycleParticipant.afterProjectsRead(TychoMavenLifecycleParticipant.java:91)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:273)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
... 11 more
Caused by: org.eclipse.equinox.p2.core.ProvisionException: No solution found because the problem is unsatisfiable.
... 20 more
