Eclipse Community ForumsHave a problem to use BPEL designer
https://www.eclipse.org/forums/index.php/mv/msg/2245/6473/#msg_6473
Originally posted by: arggaz.hotmail.com
Hi every body
I've recently installed BPEL designer plugin from the eclipse projet website
and when I try to create a BPEL process, the last window flashes but dont
close and so no process is created.
The only one way I can leave this window is to press cancel button.
Is there any one who has had this prob and can help me?
Mohand]]>2006-11-04T01:47:11-00:00Re: Have a problem to use BPEL designer
https://www.eclipse.org/forums/index.php/mv/msg/2245/6551/#msg_6551
Originally posted by: christian.miklos.t-online.de
Hello Mohand,
same problem here.
Can anyone help us on this please ?
Chris
> Hi every body
> website
> dont
> Thanks
> Mohand
>]]>2006-12-07T19:56:02-00:00Re: Have a problem to use BPEL designer
https://www.eclipse.org/forums/index.php/mv/msg/2245/6569/#msg_6569
We will be releasing another build soon, hopefully this will be squashed.
In the meantime, is there anything in the logs (Window -> Views -> Error
Log) ?
The only thing I know is that the namespace for the process must be
specified, there is bug if it does not work.
-m
Viperlein wrote:
> Hello Mohand,
> same problem here.
> Chris
>> Hi every body
>> website
>> dont
>> Thanks
>> Mohand
>]]>Michal Chmielewski2006-12-07T22:02:45-00:00
