Eclipse Community Forums[Acceleo] Cross models reference + Java Application
https://www.eclipse.org/forums/index.php/mv/msg/210283/674623/#msg_674623
I have two ecore metamodels. The main one has a simple reference to a class of the second one. My acceleo M2T script imports and uses both metamodels. It works well when executed as an Acceleo plugin but not when executed as a Java application. This is likely due to a problem of dependancy wrt the second model but I don't find how to fix this.
Any help would be appreciated,
Myvatn]]>Eclipse User2011-05-27T15:30:29-00:00Re: [Acceleo] Cross models reference + Java Application
https://www.eclipse.org/forums/index.php/mv/msg/210283/675146/#msg_675146
When we are running in "Acceleo plugin" mode, we are using the dependencies of the plugin. In "Java application", we are using the classpath. Does your project has a dependency with the project(s) containing the two metamodels ?
